  Soarer Central * Electrical * Cruise control from 31 into 1JZ?? Previous Previous    Next Next
John Stafford
Qld.
Soarer UZZ31 GT-L V8, limited edition supercharged. 2013 Titanium Territory, Petrol 7 seater.
Reg: 02-2010
Tuesday, January 09, 2018 - 01:56 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can I take a cruise control unit out of a 31 limited and put it into a 1JZ 30 that did not every have cruise control or do I have to get one from a 6 cylinder?
John Stafford
Qld.
Soarer UZZ31 GT-L V8, limited edition supercharged. 2013 Titanium Territory, Petrol 7 seater, 1JZ twin turbo set up for the track.
Reg: 02-2010
Friday, February 09, 2018 - 08:38 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bump, I am needing some input on this. Has anyone ever fitted a cruise control to a 1JZ? If so, what unit did they use?
Costa Tsimiklis
386.2 rwkw the old T51S setup - New Setup HKS T51R SPL -Going for 450rwkw on Pump Gas!
Reg: 07-2008
Monday, February 19, 2018 - 11:21 am, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Use the 1JZ one - the cable length is not enough on the 1UZ as the throttle is in the wrong spot.
I'm going to be doing a retrofit of cruise control as well.
John Stafford
Qld.
Reg: 02-2010
Monday, February 19, 2018 - 03:24 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Apart from the length of the cable is there any difference in the parts that go to make up the cruise control system as a whole? There seems to be a few parts to it.
How much do I expect to pay for a 1JZ cruise control? I will ask who has one in the wanted section.
Thanks for your input Costa.
John Stafford
Qld.
Reg: 02-2010
Monday, February 19, 2018 - 03:29 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a spare parts 31 in the back yard. Can I use some from that and just get the cable part from a 1JZ?
Costa Tsimiklis
Reg: 07-2008
Wednesday, February 21, 2018 - 02:04 pm, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pretty sure the motor is the same (it's the same motor as a window regulator) and the cable is different. you can try lengthening the cable or mounting it on the other side near the charcoal canister to see if it works well enough for you to continue with.
John Stafford
Qld.
Reg: 02-2010
Wednesday, February 21, 2018 - 05:22 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, Not quite ready to do this yet but will file it for when I am ready and if you could post any procedures to this thread when you do your retro fit Costa I would sure appreciate it.
Cheers John
