Wednesday, March 27, 2019 - 11:24 am, by: Tony Maxwell(Waterfeature)
Hi folks,
I've got a V8 Soarer sitting here gathering dust, it was towed here and with a fresh battery the only electrical action is the light around the ignition switch and the beeping when the door is open. No dash lights, no cranking and definitely no start.
Is there a main ignition fuse I can check? What else could be causing this huge electrical fault?
Cheers,
Tony
Chayton Erth Tinkerer queensland soarer 1uz 4lt gt V8 Street / Track plus Soarer 1uz 4lt V8 Roady Plus JJZ Sunroof spare shell /
Wednesday, March 27, 2019 - 11:43 am, by: Chayton Erth(Canetoad)
G Day Tony . T he main fuses you are looking for are inside the plastic box directly behind the battery and first row at front of car . Also check the gear stick is fully in park . Is this a new car or is it a known car to you ?
