  Soarer Central * Bodywork and Exterior * Changing the Gear Shift knob? and where to buy a nicer one? Previous Previous    Next Next
Open in new windowArchive through May 25, 2007Justin Stanley25
Benjamin Spitalnic
Soarer TT 6 cylinder Beeman says. Go HARD or Go HOME!
Reg: 05-2007
Friday, May 25, 2007 - 02:20 pm, by:  Benjamin Spitalnic (Beeman102) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha yeahh $40,000 over 4 years isnt that bad.. thats about as much as im looking to put into my car to get me some rocket boosters attached hahaha
i once owned a daewoo cielo..i spend $3000 and pimped it out to the max..and yes. it was a rice burner.
never again
Peter Burrett
2.5 VVTi ST
Friday, May 25, 2007 - 05:05 pm, by:  Peter Burrett (Burrett) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The fitting instructions, if followed, make the removal, and going back to stock, very likely to be difficult, if not impossible. But it can be done without the removal of all the parts suggested.
There is no need to remove the PRNDL panel. A simple wire can be routed down the shifter hole, and back to the centre cupholder (remove the cupholder).... you need a right angle flat blade driver to lever of the stock connector, which can be seen from the cupholder. Take the Levoc wires, and attach Dick Smith brass spade connectors and insulators, after reducing their width (a file jobbie), from 2.8mm (as I recall) down to 2.5mm. These will then slide into the stock connector female (you can tape them if you wish), and then you just concentrate on fitting the shifter. The instructions for that are fine, but it didn't take me anywhere near 2 hours. More like, 2 weeks thinking and about half an hour to do..... As for the shifter loosening, use Loctite on the grub screws and really give them curry with the Allen key.... should be good for life
Nathan Herbertson
Wednesday, August 01, 2007 - 12:00 pm, by:  Nathan Herbertson (Herbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin, what was the fit and quality like on these ebay handbrake covers?
Justin Stanley
V8 GT Limited
Reg: 09-2006
Wednesday, August 01, 2007 - 05:46 pm, by:  Justin Stanley (Sne33z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the eBay handbrake cover from what i can see looks exactly the same as the levoc ones...
as you can see in this
I also have the Levoc gearknob, which I got from the USA ebay for a whopping $40! +$30 postage and it was here in 3 days... it arrived before the handbrake cover did. The only difference I think is the OD button is on the other side being from the US but I like it like that :-)
Joshua Rao
2JZ-GE
Reg: 09-2006
Thursday, August 02, 2007 - 12:29 am, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin nice laser, what quatermile time did that pull? Can you please post up the link to the USA ebay levoc gearknob. Only one I could find is this at $60,
http://cgi.ebay.com/ebaymotors/NAPOLEX-LEVOC-AT-SHIFT-KNOB-W-OD-CARBON-FIBER-LV452_W0QQcmdZViewItemQ QcategoryZ42612QQihZ001QQitemZ110136461077QQrdZ1QQsspagenameZWD1V
Thanks
Gregg Holden
Soarer UZZ31 Supercharged
Thursday, August 02, 2007 - 12:40 am, by:  Gregg Holden (Xzotic) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin Stanley wrote on Wednesday, August 01, 2007 - 05:46 pm:
From your photo the colour doesn't match at all.
Please provide the link to the original auction.
Considering you spent $40k on a Laser I can understand your logic.
Justin Stanley
V8 GT Limited
Reg: 09-2006
Thursday, August 02, 2007 - 07:20 am, by:  Justin Stanley (Sne33z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I never took the laser down the quarter mile... with that much power the gearbox's liked to explode... especially the 4WD ones I went through 3 in three years, but guys with the same power roughly do low 12s depending on how much money they have for straight cut gears and cryo treating the outer casing and how game they are.
yeah the colour is a bit different to the gearknob, its slightly brighter, being from a different company it is understandable
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=003&sspagename=STRK%3AMEWN%3AIT&viewitem =&item=130123479723&rd=1
is the link to the original auction, he had like 8 of them up for sale all $40 starting bid or $70 buy it now... only the two wood ones sold from what I saw
The TX3 4WD turbo laser was fun :-) that was my logic... pushing the OD button with my index finger instead of my thumb just feels right haha
Alen Sadikovic
Soarer GTT
Reg: 10-2006
Thursday, August 02, 2007 - 08:19 am, by:  Alen Sadikovic (Alen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, i have a levoc gear knob as well and i dont suggest it, its all plastic fantastic and i payed for my one almost $300 including the hand brake Knob.
the hand brake knob just clips on from the top and the gear knob isnt even original, the main screw is on the wrong side, so all that is holding the knob is the damn three little screws (which losen up time to time)
if you can get it for less then $100, get it if your really want it, other wise spend your money on something betta :-)
Justin Stanley
V8 GT Limited
Reg: 09-2006
Monday, August 06, 2007 - 04:08 pm, by:  Justin Stanley (Sne33z) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The same guy has them up on his ebay again... all the styles, but being US the OD button is pushed with your index finger instead of your thumb...
http://motors.search.ebay.com/search/search.dll?sofocus=unknown&sbrftog=1&catref=C6&from=R10&satitle =Levoc&sacat=-1%26catref%3DC6&fmmk=&fmmd=&fylo=&fyhi=&mppfqy=Levoc&sadis=200&fpos=2077&sabfmts=1&sao bfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&seller=1&sass=hinomarugifts&fsop=1%26fsoo%3D1&coaction=c ompare&copagenum=1&coentrypage=search&fgtp=
Chris Lock
sa
celica
Reg: 03-2008
Wednesday, August 20, 2008 - 08:12 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So.. anyone else got any opinions about these?
I'd like to get something like this, but don't want to waste my money if they're crap.
XTR T-66 Turbo
Wednesday, August 20, 2008 - 08:48 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive got one in my car mate and im pretty happy with it.
I did lower it at little though as it sat a little to high for me.
The quality is ok i guess but they have always been pretty expensive. Depends on the look you are chasing.
I went with chrome and white and it works well as it matches my boost gauge and chrome bevel thingo.
Chris Lock
sa
celica
Reg: 03-2008
Wednesday, August 20, 2008 - 09:18 pm, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was going to go woodgrain to suit the woodgrain interior..
So no problems of it coming loose as mentioned by others?
Mercedes Benz SLK230 Kompressor
Thursday, August 21, 2008 - 07:18 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris Lock wrote on Wednesday, August 20, 2008 - 09:18 pm:
Chris, I had the woodgrain Levoc knob on my Soarer for 3.5 years, and had no problem with the installation OR with it coming loose...........Recommended.
