Miles Baker
DieHard Vic 66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 73 Corvette 4sp T-Tops
Posts: 700 Reg: 08-2005
| Any painters around? I'm gonna try my hand at a bit of painting over the weekend. Yes I know PPG paint is cheap stuff, but it's my first try. What I have is PPG Dulon AAA Mixed Colour acrylic. It is a metallic. The paint says to use one of the following thinners: "Dulon Thinner 922-34353, 922-34178, 922-43032". However, the paint shop gave me "Dulon Multi-Midway Thinner 921-01074". On the back it says "A multipurpose thinner for use with lacquer products". Do I need to go swap for the other stuff??? |
Brian Timms
DieHard New South Wales TT Soarer Goodness.
Posts: 502 Reg: 12-2006
| it should be fine, because the thinners make the paint thinner to get through the gun, and then evaporate as it dries on the pannels. thing to be careful of is bubbles on the paint work, dont think you can thin the point out and blend it in by adding more thinners (like my cousin did) as you will be sanding the job off next week and re-doing the job. B. |
Trader NSW I have a Cadillac and a Supercharged Manual V8
Posts: 4077 Reg: 07-2005
| All I know is. It's WINTER, so let each LIGHT application DRY before getting into it again. Other wise the paint will fall off. hahahahah |
Goo Roo North Island JZZ31
Posts: 2762 Reg: 10-2005
| Good luck Miles, its something I'll never try again! |
Miles Baker
Posts: 702 Reg: 08-2005
| Called the paint shop this morning, they said it was the right stuff. Apparently the labels have changed recently. I'm only painting a few little areas. Prep and masking are the worst. Hate it. |
Jeff Wilkins
TryHard South Australia JZZ30 GT-TL
Posts: 415 Reg: 07-2005
| Warm the areas your spraying Miles, if ya can. Anywhere around the 25-27C mark is excellent, also warming your paint will help a lot also (dont get it too warm though or your thinners will leave before your ready for it to). As Neil mentioned, cold days/panels makes runs REALLY easy. If you can get your panel warm, about 5-8 minutes should suffice for flash off between coats. |
Miles Baker
Posts: 704 Reg: 08-2005
| Thanks Jeff! I'm doing a firewall and the interior of the car is out. I might try a heater inside the car, and sit the paint tin in a tub of warm water? |
Jeff Wilkins
Posts: 416 Reg: 07-2005
| yeah the heater on the inside should do the job. The paint doesn't need to be as warm as the panels, merely not cold if ya know what I mean... |
Miles Baker
Posts: 706 Reg: 08-2005
| Yep. Factory gets freakin cold though. Probably be about 5 when I get there tomorrow morning. |
Posts: 4080 Reg: 07-2005
| Miles, Home Hardware sometimes have Twin 500W worklights cheap ( $50 ) these WILL warm the panels and keep you warm 2 Pak will dry harder if left to dry by itself. |
