  Soarer Central * Bodywork and Exterior * Confirm this colour Previous Previous    Next Next
Derek Cheong
Not yet
Monday, November 12, 2007 - 01:00 pm, by:  Derek Cheong (Soarerboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello all,
Please look at this Soarer,
I haven't seen any others with this colour. Is it likely to be a respray colour change?
Thanks
Nik Gacomi
Reg: 05-2006
Monday, November 12, 2007 - 01:06 pm, by:  Nik Gacomi (Snoopie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think its called gun metal grey
Soarer VVTi
Monday, November 12, 2007 - 01:25 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Spruce. Very very nice colour.
Monday, November 12, 2007 - 03:10 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Derek,
That is a standard Soarer color.
Toyota paint code is:
6M3. Officially known as "Grayish Green Metallic", but commonly referred to as "Teal".
Derek Cheong
Not yet
Monday, November 12, 2007 - 03:24 pm, by:  Derek Cheong (Soarerboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK thanks Don
Chris Prak
Soarer GTT-L
Reg: 12-2006
Tuesday, November 13, 2007 - 04:42 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mines that colour. Good luck finding the paint code. Had to custom mix mine and it turned out like crap haha.
Dave Rose
wa
uzz31 v8 97
Tuesday, November 13, 2007 - 10:45 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Tuesday, November 13, 2007 - 11:18 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Colour code is on the plate in your engine bay.
Chris Prak
Soarer GTT-L
Reg: 12-2006
Wednesday, November 14, 2007 - 03:00 am, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, but they no longer have the actual colour apparently. 6M3 from Toyota is now a silver spruce found on the estima family wagons and camry's, so paint shops do not know what to mix, so custom is the only way if you want to paint your kit.
Haydn Crandell
TT 2.5
Thursday, November 15, 2007 - 07:58 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris Prak wrote on Wednesday, November 14, 2007 - 03:00 am:
it wouldnt be hard to mix the colour up, spray painters have colour swatches they use when a colour does not come up on there system.
find it hard to believe that colour doesnt come up on the system.
I will punch it in ours when i go back to work .
Chris Prak
Soarer GTT-L
Reg: 12-2006
Thursday, November 15, 2007 - 08:15 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I think the panel beater was a bit slack. I got my bumper sprayed, the paint is fine in the shade, but when in the sunlight, it's complete wrong. I guess he used the wrong pearl through it?
Haydn Crandell
TT 2.5
Thursday, November 15, 2007 - 09:05 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not even sure if there is pearl in it,
probably metallic more then anything, thats why it is better to blend into the next panel . pretty had matching pearls and metallics .
even new cars look slightly differant on the bars to the rest of the car . to the trained eye anyway
Dave Rose
wa
uzz31 v8 97
Thursday, November 15, 2007 - 10:38 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wonder how many 94s in 6n1 were made??
Haydn Crandell
TT 2.5
Friday, November 16, 2007 - 08:50 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
like don said it is known as Greyish green Metallic , silver spruce is the same .
it has 6 colours to make it up .
Medium Silver
Effect Additive
Mid Blue
Sparkle Silver
Jet Black
Tinting Black
Daryl Demarte
IS300 & UZZ32
Tuesday, November 20, 2007 - 08:36 pm, by:  Daryl Demarte (Helieng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was at the local panel beater the other day and checked the Soarer 6M3 colour. It is indeed Greyish Green Metallic(known as Teal) and is shown in the Glasurit computer colour chart and also on the colour prophey card system at Glasurit dealers. Can be mixed no problems. Check it out.
