  Soarer Central * Bodywork and Exterior * Attaching Body Kit ??? Previous Previous    Next Next
Heath Fox
Soarer 4.0GT UZZ30
Thursday, November 15, 2007 - 04:45 pm, by:  Heath Fox (Lilfoxy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
I just received my new side skirts and rear apron today. I was going to fit & spray them after my exams in a few weeks, but in my excitement i have already sat them along the car to check the fit.
I have a few questions though:
1/ I'm just wondering if there are any specific screws to use, or are the factory ones in the mud flaps fine? & what is used under the number plate to attach the apron?
2/ Where do you get the 3M double sided tape everyone seems to use during fitting?
Haydn Crandell
TT 2.5
Thursday, November 15, 2007 - 07:46 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1.use rubber washers so you dont crack the fibreglass.
2.dunno.need more info.got a pic?
3.any Panel Beater/Spray Painter.
Heath Fox
Soarer 4.0GT UZZ30
Thursday, November 15, 2007 - 10:28 pm, by:  Heath Fox (Lilfoxy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found out the tape is 3M VHB tape(4950) but costs an arm and a leg.. US$77 per roll.
Looks like this:
Haydn Crandell
TT 2.5
Friday, November 16, 2007 - 09:52 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats a rip off, go to any panel beater and buy it from them only what you need .
we use double sided tape all the time and isnt that expensive
Joshua Rao
2JZ-GE
Reg: 09-2006
Friday, November 16, 2007 - 04:39 pm, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is that how body kits go on? Just double sided tape and a few screws?
Haydn Crandell
TT 2.5
Friday, November 16, 2007 - 07:36 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep, didnt even use double sided tape on mine
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Saturday, November 17, 2007 - 04:31 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They also used a little bondo to smooth out the finishing lines on mine.
Kanchana Pathirana
3ltr straight 6
Saturday, November 17, 2007 - 11:54 am, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what about poly uthrene (think thats how you spell it) glue...dont they use that????
Haydn Crandell
TT 2.5
Saturday, November 17, 2007 - 06:26 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
also know as sikaflex they use it in windscreens .
you need to make sure you have it fitting pretty good from the start before you go playing with sikaflex, messy stuff.
works well.
http://www.sikaindustry.com/tds-ipd-sikaflex295uv-us.pdf
Heath Fox
Soarer 4.0GT UZZ30
Saturday, November 17, 2007 - 08:41 pm, by:  Heath Fox (Lilfoxy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Dave what's the 'bondo'?
Hayden, got that price from 3M website, but saw some for $2 today, I'm sure it wouldn't hold like the industrial 3M stuff though.
Looks like a fair bit of work to get it to fit right. Front bar fitted with only minor alterations (bought form another place), this rear lip (Vertex copy) has some issues trying to sit it flush and it doesn't have that little flair out just after the rear wheel.
When i get them fitted I'll post some pics.
Haydn Crandell
TT 2.5
Saturday, November 17, 2007 - 08:46 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
honestly you dont need double sided tape to hold a kit on.
the tape is more for badges ect.
Dave Billings
Louisiana
Reg: 06-2007
Sunday, November 18, 2007 - 01:19 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bondo as kinda like plaster in a way. Say, its easier to bondo a car b/c it smooths out nicely.They've used that stuff starting in the mid 1980's as a cheaper and faster alternative to replacement of body parts. It kinda fills in the "gaps"
Miles Baker
66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 73 Corvette 4sp T-Tops
Sunday, November 18, 2007 - 05:49 pm, by:  Miles Baker (Milesb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bondo = polyester resin + talc filler
Steve Petkos
Soarer GTTL
Saturday, November 24, 2007 - 04:09 pm, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bondo = bog or body filler for us in Aus.
