  Soarer Central * Bodywork and Exterior * Ebay Soarer Body Kit Previous Previous    Next Next
Open in new windowArchive through January 30, 2008Haydn Crandell25
Haydn Crandell
TT 2.5
Wednesday, January 30, 2008 - 09:07 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew if i was you i would be sanding the paint around the area you are putting that fibre tough bog on,trust me it peels off shiny surfaces.
Luke Burt
Reg: 08-2007
Friday, February 01, 2008 - 04:09 pm, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats the kit i got, same seller.
I will show you my end results for my fitting when i get around to my thread. I did no modifications to the fibreglass. Slight bit of filing, about 10 minutes worth no more.
Keen to see the pics of your kit painted and fitted andrew.
Andrew Oils
V8 - UZZ31- Limited
Reg: 01-2008
Friday, February 01, 2008 - 06:39 pm, by:  Andrew Oils (Sc400_au) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Obviously I've ended up with a VERY bad kit, or possibly I'm too detailed and wont drive around with gaps I see so often on other cars. Trust me when I tell you this kit needed a lot of work. I happen to have some close associations with a panel shop in QLD so I've been lucky to have a lot of experts and advice on hand, but if anyone of you is keen on a spot-on finish with little modifications/work, then this is not a kit for you. Unless you are prepared to pay big $$ for modifications or are a sculptor or maybe lucky with a better mould, you better stay away from this shonky back yard operator in Qld. Incidentally, he agreed the kit was faulty, promised a partial refund and still did not come through with the agreed $$. I will post pics as soon as the car is shipped back here to NSW. Finalising fitment etc....Also, thanks for the link, yes this is the dodgy seller on Ebay and as you can see, the front bar he is advertising, is not the bar I have received. In other ad he describes this kit as "Brand New Vertex", which of course it isnt..In the ad you've linked up to above, he can not even spell "Brand", so I guess that tells you the stroy...quote:"*You are bidding on a brane new BN-Sports Soarer bodykit*"...
Luke Burt
Reg: 08-2007
Friday, February 01, 2008 - 06:51 pm, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You got a different front bumper than the one in his ad?
Keen to see pictures of it when your all finished mate, my bumper is vertex as the pictures show. He seems to think his kit is a BN one but it's all vertex.
Luke Burt
Reg: 08-2007
Friday, February 01, 2008 - 06:53 pm, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah true just saw a picture of your front bar above, that does seem weird..
Ah well, at least you know the guys at the panel shops so it shouldn't have cost you too much in the end.
Andrew Oils
V8 - UZZ31- Limited
Reg: 01-2008
Monday, February 25, 2008 - 12:22 am, by:  Andrew Oils (Sc400_au) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, here is the final result from a distance.
Looks just as good up front. If anyone of you need detailed pics/horror details etc, let me know.
Aaron Casey
Monday, February 25, 2008 - 01:12 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
andrew good to see its now finished and looking good, was a pity you had to go through so much just to get it to fit but the result looks good from the pics :-)
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Thursday, March 13, 2008 - 05:26 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Haha, looks like mine when she was black before her respray. Great work. Can you post more pics in the sunlight, kinda hard to see the details...it's rare to see another kit like ours posted. Thanks in advance, mate.
