  Soarer Central * Bodywork and Exterior * How do I remove this bumper/guard type thing on my soarer? Previous Previous    Next Next
Andrew Poh
Waitakere
AE111 black top 20v bz-g levin
Reg: 08-2008
Tuesday, September 09, 2008 - 07:35 pm, by:  Andrew Poh (Drewpoh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey I want to know how to get this plastic bit off my Soarer (see picture), there's rust between the plastic and the metal, and I need to grind under it, so I need to remove it.
Steven Roduner
Reg: 01-2008
Tuesday, September 09, 2008 - 09:54 pm, by:  Steven Roduner (Steve89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I second the request. Tute for removing the whole rear bumper and other parts would be great.
Steve Giordano
Alberta
Thursday, September 25, 2008 - 05:48 pm, by:  Steve Giordano (Steve_101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes taking the surrounding parts would be great
IE the rear facia, if its rusting along the bottom it may be all the way across.
Rear bumper comes off very easy there are parts in the inner of the trunk that have to be removed to get to 2bolts there and there is one on the inside of the wheel well. as well as one joining the addon to the rear bumper
