Tuesday, October 14, 2008 - 02:47 pm, by: Brett Harris(Stay_beautiful)
My Drivers side window does not close fully. Stops about 5mm short of being fully closed and am not sure why
I was wondering if there was a simple adjustment that could be made to fix this problem as it's a pain when I wash the car(not quite daily anymore since the colonic)
Tuesday, October 14, 2008 - 08:20 pm, by: Brett Harris(Stay_beautiful)
Hi James, Would you believe I bought it from a car yard in QLD and not one piece of service history? (yeh, I couldn't believe I did either) But in my defence, factory 5 speed with limited slip diff, really clean interior and engine bay.
Wednesday, October 15, 2008 - 05:22 pm, by: Mike Beck(Gold_40gt)
To solve this, loosen off the two strange bolts holding the window,
Raise the window up, put the two bolts back in.
Then rest the window on top of the bolts in between the bracket.
Tighten them up so they hold the window. I did this on mine and its been working great, my window is well lubricated too so that would help stop it slipping out if theres the possibility of that.
Reason for doing this is I used newer 96 Regs in a 91 Door.
