Sunday, October 26, 2008 - 12:04 pm, by: Razvan Petrescu(Raz)
After having the car parked underneath a tree about a week ago, I found that I have all these clear, gooey type of blobs (from very tiny to larger sizes) all over the car, and there are a lot of them. I suspect they would be tree sap. The bad thing is I don't know how to remove it. I have washed the car several times, while I was able to remove the larger blobs, the tiny ones are quite hard to remove. Anyone have any recommendations of how I would be able to remove these? I have tried out FW1 cleaning Wax which I have (contains CARNAUBA) but it hasn't helped.
Daniel Lee Goo Roo Victoria Soarer GT Limited UZZ31 V8
Sunday, October 26, 2008 - 04:23 pm, by: Mike Triggs(Mikeandimah)
You might try isopropyl alcohol (sold as rubbing alcohol and sometimes as glass cleaner) or other solvent if you want (try on an inconspicuous area first, to check for possible paint damage). I've used it with success on tree sap, which is an issue where we live, but of course tree saps vary markedly in composition.
We use isopropyl alcohol for cleaning glass instruments.
Sunday, October 26, 2008 - 06:54 pm, by: Razvan Petrescu(Raz)
Cheers, I used isopropyl alcohol on the whole car yesterday and that helped a bit. I tried wiping with hot water today and was good as well. I will probably have to repeat this a few times. I am almost tree sap free. The hot water seemed to be the best at the moment.
