Monday, December 08, 2008 - 03:45 am, by: Kane Chan(Fumoffu)
I found someone selling some aftermarket wheels off a 2008 Nissan Altima, I'm wondering will it fit the Soarer? The bolt pattern is 5x114.3, and it has 35mm offset riding on tires that are 245/40r18. I have no idea if this will affect the handling on the car or if it'll fit.
Monday, December 08, 2008 - 09:11 am, by: Mike Dobkin(Razman)
For some reason air suspension cars seem to be more sensitive to offset problems (tramlining etc) but if your car is shock & coil then both will suit it fine.
Wednesday, December 10, 2008 - 11:50 am, by: Scott Casey(V8soarer_1991)
get some hub centric rings that will seat onto the hub center.
which allows to position the mag wheel like if it was factory. Reduces the chance of wheel even though being perfectly balanced feel like they are not.
any "decent" tire shop will stock them and put them on the car when you put the mags on.
std soarer 45 supra 50
does not matter about the offset as long as the tire it does not rub on the outer guard and the wheels rub on the caliper
