  Soarer Central * Bodywork and Exterior * Sill fix Previous Previous    Next Next
Mike Bradberry
Wednesday, November 16, 2005 - 06:03 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know it's been covered before but I can't find it. My drivers side sill next to the glass has the common crack in it and if I don't fix it the vinyl will tear eventually.
Does this mean I have to remove all the door trim to get at it?
Robert Petrovski
Wednesday, November 16, 2005 - 06:17 pm, by:  Robert Petrovski (Robche) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep. sure do
Jeff Hogan
Wednesday, November 16, 2005 - 06:39 pm, by:  Jeff Hogan (Hoges) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
do you mean the trim around the window? you dont have to take all the door trim off to get to that, i dont think anyway...? i think you just have to remove a couple of screws under the plastic cover on the leading edge of the trim, then it just clips out? or are there screws along the bottomw edge under the top of the door trim? sorry its been a while since ive taken mine off
Jeff Harper
UZZ32 Active V8
Wednesday, November 16, 2005 - 07:26 pm, by:  Jeff Harper (Jeffh) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes it all has to come apart.
Mike Bradberry
Wednesday, November 16, 2005 - 08:02 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys (I think?)
1991 UZZ30 GT4.0 V8
Wednesday, November 16, 2005 - 08:34 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike, use the on-line parts catalogue (On this site), and select "Body", then select "Doors", and you'll see an exploded parts diagram, which shows the location of the retaining screws & stuff.
