  Soarer Central * Bodywork and Exterior * REVERSEING CAMERA ON LATE MODEL SPOILER Previous Previous    Next Next
Dave Rose
wa
uzz31 v8
Friday, February 13, 2009 - 09:33 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wanted to get the camera up as high as i could for a good angle , worked out better than i thought.
Dave Rose
wa
uzz31 v8
Friday, February 13, 2009 - 09:41 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry did not mean to shout forgot i had cap locks on and could not edit title.
David Grab
T78
Reg: 01-2008
Friday, February 13, 2009 - 09:45 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was actually thinking of going an aftermarket camera for my JZZ30 and installing it under the rear bar. I like the technology part of a reverse camera but dont like the look of them been so prominent. Your one i dont mind actually, you should paint the black housing the same colour as the car and make it look more subtle and factory :-)
Dave Rose
wa
uzz31 v8
Friday, February 13, 2009 - 10:16 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes I was going to paint it ! but you have to get down to find it ,if you walk round the car you do not see it.
looks bigger in the photo than it is(only 55 cm long).But then again i may paint it....+++ jpeg +++ 279135 +++ Upload +++
Dave Rose
wa
uzz31 v8
Friday, February 13, 2009 - 10:18 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Soarer VVTi
Tuesday, February 17, 2009 - 03:06 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I like that. Which camera did you use? (besides reverse )
Dave Rose
wa
uzz31 v8
Tuesday, February 17, 2009 - 04:04 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Josh it was on e bay from the USA
www.alpha-bid.com or gerry@alpha-bid.com
