Sunday, May 10, 2009 - 05:25 pm, by: Mike Dobkin(Razman)
If you are just going to connect them to a relay then you won't have to remove them from the body - just remove the lower plastic arch liner and you will see the connectors on the back of the lights.
Sunday, May 10, 2009 - 08:26 pm, by: Ryan Rankovic(Ryan1j)
the lights have 4 bolts coming from the back with bolts securing it into the bar. in the corners. if you can see the back of the light, you will be able to see the bolts
