  Soarer Central * Bodywork and Exterior * Permanent removal of lower turning light units. Previous Previous    Next Next
Michael Mockiewicz
Reg: 09-2009
Sunday, October 25, 2009 - 07:12 pm, by:  Michael Mockiewicz (Mikez30) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've decided I am going to be removing my lower turning light units (which are not functional anyway) & then cut the plastic pieces (with the hole in either one) for where the nuts hold the units in place. Though, there will still be the screw hole from the top of the unit if I changed my mind. So then I am left with 2 ducts on either side of my bumper. Most likely more of an cosmetic mod once I have cleaned up & smoothed where I have cut the plastic. A little more air-flow can't hurt though.
I will also be purchasing some new after-market headlights / high beams, so the turning lights will not match up anyway. I am also anal about the flow of things & miss-matched parts.
Has anyone else tastefully removed these permanently ? Aside from the people who have changed over to an after-market front bar where there is no longer provision for the turning units / fog lights, anyway.
Cheers,
Mike
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Sunday, October 25, 2009 - 07:23 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you want it it to be flawless .. I'd:
Remove lights.
tape down inside of cavity
apply builders bog
dry
sand with 400
sand with 1000
Sand with 1600
Sand with ++++
Paint.
Aaron Casey
Sunday, October 25, 2009 - 07:46 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im interested to see how ou delete the middle vent that goes into the light and how it will look smooth. but i have vertex so no need for me. get alot of pics while you do it.
