  Soarer Central * Bodywork and Exterior * Wide front gards in aus??? Previous Previous    Next Next
Narvey Vilaythong
soarer tt and 3T-GTE corona liftback
Reg: 09-2009
Tuesday, May 04, 2010 - 01:47 am, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys, just wondering if anyone in AUS can supply aftermarket front gards for the soarer. I remember there was someone in aus who did but that was ages ago. my reason for wanting one of these is that run work equips 18x9 +35 on the front with 245/35/18 tyres and they stick out approx 10-15mm more. And i dont really like the look of flared gards as it will loose its sexy smooth look
Matt Petersen
NA
Reg: 01-2008
Tuesday, May 04, 2010 - 04:42 am, by:  Matt Petersen (Mattmannz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I run Work XD9s in 18x9 + 38 on the front with no issues at all. They are flush.
Matt.
Guy Moore
JZZ30 TT M/T
Reg: 03-2010
Tuesday, May 04, 2010 - 07:28 am, by:  Guy Moore (Thesoarerguy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vertex as well they have a Australian site too they make +25mm and +50mm front and rear guards.
Soarer 2.5GT-T/GS300
Tuesday, May 04, 2010 - 01:40 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You shouldn't need to run wider guards. Just roll them and you'll be fine.
Narvey Vilaythong
Reg: 09-2009
Tuesday, May 04, 2010 - 06:29 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
would body roll effect it? im 99% sure the tyres is just going to get shreaded on one hard turn
Evan Nguyen
Soarer TT manual
Tuesday, May 04, 2010 - 07:22 pm, by:  Evan Nguyen (Enguyen87) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've had 17x9 +19 and 19x10 +35 on the front of my soarer and they don't rub with a guard roll. There's no need to run crappy fiberglass guards unless you really require it.
Ali Saeed
Wednesday, May 05, 2010 - 01:16 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
19x10 on the front? lol
Narvey body roll can easily be removed by a super hard suspension :p
Narvey Vilaythong
Reg: 09-2009
Wednesday, May 05, 2010 - 10:17 am, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im just worried as i will be running JZA80 Bilstiens and people have said they will make my car sit very low
Ryan McDonough
STOCK JZZ30 TT
Wednesday, May 05, 2010 - 02:31 pm, by:  Ryan McDonough (Ryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
18*9.5 +38 here with a 235/40 with no rub at all. You could always run a skinner tire as well to help with clearance.
Narvey Vilaythong
Reg: 09-2009
Wednesday, May 05, 2010 - 04:40 pm, by:  Narvey Vilaythong (El_pablo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nah, lesson learnt with streched tyres, easier to gutter and if you turn hard enough, the tyres will roll off. Anyone good pictures of soarer with rolled gards?
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Wednesday, May 05, 2010 - 05:29 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah a bloke selling his on here 380+ rwkw black one.
UZZ31 V8 LTD
Reg: 03-2009
Wednesday, May 05, 2010 - 05:31 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
318* and
http://soarercentral.com/sc-forum/messages/5079/315971.html?1272702291
that's flared guards.
