Wednesday, May 05, 2010 - 03:13 pm, by: Michael White(Zeph312)
Ok this is probably a stupid simple question but the side repeater indicator on the passenger side if smashed the glass, and bulb, i dont know how/when, i swear it wasnt me. Anyway i have a new fitting/glass/bulb the whole lot. So here is the stipid question...
How the hell do you get to it? from the spare unit i can see it is just 2 bolt holding it in but i can find the damn thing from any angle. i used the search thing and no one seems to of ever writen about changing one.
Wednesday, May 05, 2010 - 03:59 pm, by: Adam Lonergan(Alchemistal)
I should also mention that only a foolish man forgets to test everything before reinstalling the plastic guard and wheel.
The last one I removed from a wreck simply by using an 8mm high speed drill like a router and cutting the whole area out of the damaged bar and then just unplugging the indicator. I wasn't going to waste too much time and this took less than two minutes, but obviously this is not an option for you.
