Wednesday, July 14, 2010 - 06:58 pm, by: Tony Wang(Soartosky)
hi all, I am in the process of repainting my driver side door, and I tried to remove the door handle. The problem is, there are three 10mm bolts need to be removed to get the handle off, two on topside and one of them is really hard to access. Is there a special trick to get it off? like any other parts I should remove before attempting it? I got the metal rods off, still no luck getting to that topside inner bolt.
Wednesday, July 14, 2010 - 07:32 pm, by: Richard Luong(Reggiebangbang)
Use a torch and you are looking from the inside of the door on the right you should find a hole at the same height from where you removed the first 10mm bolt, this is where you can stick a 10mm socket with a socket extender you should be able to unscrew it.
