  Soarer Central * Bodywork and Exterior * Fitting mesh into front Bar Previous Previous    Next Next
Nathan Machin
SC300
Reg: 06-2009
Thursday, July 29, 2010 - 12:37 am, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey boys and girls
can anyone help me out, how do you attach the mesh to the front bar to fill the holes????
If that makes sense
Ali Saeed
Thursday, July 29, 2010 - 12:59 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
mine is fibreglassed on..so that might be an option
Michael O'Driscoll
Thursday, July 29, 2010 - 01:24 am, by:  Michael O'Driscoll (Remickz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine had a few small holes in the bar, with some small cable ties holding the mesh in.
Daniel Arndt
UZZ31 LTD
Reg: 03-2010
Thursday, July 29, 2010 - 07:10 am, by:  Daniel Arndt (Darndt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive used Sikaflex before, takes a while to dry, so need to hold it there for at least 24hr. with clamps or tape. Its messy stuff though. don't get it anywhere you DONT want it.
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 09:30 am, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Use wire fiberglassed to the bar, then intertwine the wire through the overflow of mesh, you wont see it and itll hold like anything. Plus its easy as pie to take off.
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 09:31 am, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ohh, use wire thick enough to twist, but still strong, just thinner then a coat hanger.
Nathan Machin
SC300
Reg: 06-2009
Saturday, July 31, 2010 - 01:34 am, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers for the ideas guys
Aaron Casey
Saturday, July 31, 2010 - 05:04 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
as daniel said most of my bars have a nice dab of fibreglass body filler repair with mild steel fencing wire or the like then as you slide the mesh over it bend it down and holds fine.
just dont use spring steel or stainless as may crack the bar trying to bend it cause would need more pressure to bend it lol
