  Soarer Central * Bodywork and Exterior * Nissan r35 bonnet scoop Previous Previous    Next Next
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Monday, January 17, 2011 - 05:12 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does anyone know were i can get a set of the r35 bonnet scoops? ive been looking and only found 1 set which are carbon fibre but im only after the standard plastic ones.
Matt Sartori
Rx7
Reg: 08-2008
Monday, January 17, 2011 - 05:47 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They're called NACA Duct's if it helps at all.
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Tuesday, January 18, 2011 - 06:50 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks, but still no joy. anyone else got any info?
Matchy Loi
GTT
Tuesday, January 18, 2011 - 09:11 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There's some on eBay from America. NACA ducts that is.
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Wednesday, January 19, 2011 - 03:09 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
should be NACA ducts everywhere, they are a very old design but work well.
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Wednesday, January 19, 2011 - 05:42 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im not really looking for them to be to functional, its more about cutting the big reverse dent i have in my bonnet that the former owner put there after he put a custom throttle body on. he didnt check it would fit before he closed the bonnet before he slammed it shut. the high bolt have been lowered but im left with a big high point and i thought a set of those scoops would be go just in the right place to fix it.
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Thursday, January 20, 2011 - 07:33 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the paintless dent removal guys do some magic work, but if you want the vents they shouldnt be hard to find, theres a ton on ebay.
