  Soarer Central * Bodywork and Exterior * Removing front passenger side guard? Previous Previous    Next Next
Louis Francois
Reg: 11-2010
Monday, June 06, 2011 - 11:18 am, by:  Louis Francois (Lewiis) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi went through the forum but couldn't find info as to how to remove the front passenger side guard, anybody can send me a link or comment?
Much appreciated.
Tom Brookes
Nil
Reg: 03-2010
Tuesday, June 07, 2011 - 04:49 pm, by:  Tom Brookes (Aristor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have seen a diagram of all the bolts, rivets somewhere on here. I can't find it again using search.
Nathan Smith
Reg: 04-2009
Tuesday, June 07, 2011 - 05:48 pm, by:  Nathan Smith (Zanjara) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Remove the two nuts that hold the front bar to the guard. you have to remove the plastic push screws on the splash guard liner to gain access to them. They will be a 10m bolt. 3 bolts in the engine bay. there is 2 under the guard near the sill panel and there should be 2 bolts where you open the door one at top and one at the bottom. Also you may need to remove the plastic push screws from the fender lining.
Hope that is of some help.
