  Soarer Central * Bodywork and Exterior * Supra Style Tail Lights - Error Code Fix Previous Previous    Next Next
Peter Bullman
Monday, March 12, 2012 - 10:14 pm, by:  Peter Bullman (Pete) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
G'day everyone, I have done a quick search but couldnt get the wording right to get the right answer..
Ive got the above tail lights - not installed yet - but I know that you get the error message when they are installed. Im sure I have read somewhere here in the past that you can run a resistor in one of the looms to stop the error from occurring.
Can someone advise what resistor to use and where to install it?
Thanks in advance!!
Pete
Peter Bullman
Thursday, March 15, 2012 - 12:43 pm, by:  Peter Bullman (Pete) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nobody..?
Peter Bullman
Thursday, March 15, 2012 - 01:52 pm, by:  Peter Bullman (Pete) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found it! Simply cut the purple wire leading into the lamp failure module located in the boot in the driver's side quarter. :-)
