Wednesday, February 13, 2013 - 10:07 pm, by: Orton Marchant(Mythorite)
First majorly, im sure i can source a new windscreen from somewhere but, is there away to fit a second hand screen in? Also airbags. don't know where to start. I can get a new wheel simple, but passenger side would this require a full new dash, pre-tensioner in seatbelts? and air bad module would i need to replace the old airbag module?
Friday, February 15, 2013 - 08:51 pm, by: Ian Johnston(Ted)
A little more info may get results. I gather you have had a bingle(not a Lara) New screen is the way to go. Windscreens O"Briens. Put up some pics, and may get more help as well.
Saturday, February 16, 2013 - 10:02 pm, by: Orton Marchant(Mythorite)
Sorry mate, was tired when i wrote this. Was wondering what would need to be done. For example ecu replaced? whole dash?? For passenger airbag. Seatbelts, airbag sensors?
Would i be able to take another windscreen off another soarer by any chance?
Ian Johnston Goo Roo South Australia 1995 UZZ31, BA XR6Turbo Ute. 2007 VE GTS.
Sunday, February 17, 2013 - 10:06 am, by: Ian Johnston(Ted)
Yes you could use a 2nd hand w/screen, but cost of getting out etc may make it cheaper to get new one. I dont know enough about the airbag systems and all that to make any comment. The damage doesnt go back to the screen pillar does it? Bit hard to see in your pics, but need to have a good look, and make sure you dont have any chassis damage.
And, just send me the old front bar when you get the new one
Sunday, February 17, 2013 - 11:11 am, by: Dave Rose(Sand_groper)
I see its a 97 so the seat belts would have fired no sure if you can just replace gas tube only Drivers air bag and clock spring no problem, G sensor should reset unless damaged, looks like replace dash unless you can replace airbag and have the dash plastics welded.
Monday, February 18, 2013 - 08:27 pm, by: Orton Marchant(Mythorite)
Thanks for the info, unfortunaly there is chassis damage, the right and side bit that holds the reobar is bent in by an inch, it looks like a possible cut and weld as most of it is spot welded on. That bar is mine ima repair it because still worth it haha.
On a side note, can get steering wheel and already have seatbelts. Dash is also possible im just worried about sensors and the windscreen. I know obrien will most likely do it but i heard they have tried to charge someone like 700 for the window itself.. :S I just want more details to see what has triped really i guess
