  Soarer Central * Bodywork and Exterior * Front bumper clips/plugs Previous Previous    Next Next
Jack Lloyd
Northern Territory
Reg: 01-2012
Monday, February 24, 2014 - 02:12 am, by:  Jack Lloyd (J_lloyd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone have a part number for the clip things that hold the front bumper on?
Ones just under the headlight.
David Grima
92 JZZ30 TT & 91 UZZ31 V8
Reg: 07-2007
Monday, February 24, 2014 - 02:31 am, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have you tried Toyodiy.com?
Jack Lloyd
Northern Territory
Reg: 01-2012
Monday, February 24, 2014 - 07:30 am, by:  Jack Lloyd (J_lloyd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I always do first but the diagrams aren't showing up, might need to jump on a computer..
Ali Saeed
RSP JZZ30
Monday, February 24, 2014 - 10:06 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
toyodiy diagrams are down for some reason
Ali Saeed
RSP JZZ30
Monday, February 24, 2014 - 10:26 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyway the part number for the clips that hold the bumper in place under the headlights is:
90467-09128 and you need 6 (3 each side)
David Grima
Reg: 07-2007
Tuesday, February 25, 2014 - 07:47 pm, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From memory when I took my front and rear bumpers off to respray them, they pretty much just looked like these.
http://www.ebay.com.au/itm/TRIM-CLIP-BODY-CLIP-FASTENERS-HONDA-NISSAN-25pkt-/290538249549?pt=UK_WSJL _Wholesale_GL&hash=item43a56ddd4d
