  Soarer Central * Bodywork and Exterior * Crystal clear headlights Previous Previous    Next Next
Anish Varsani
V8 UZZ30
Saturday, February 25, 2006 - 04:25 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was doing the Meguiars 3 step thingo to my paint work with an electic buffer this morning.
The paint cleaner works a treat at cleaning the dull coating off the headlights. Beats having an expensive bottle of plastic cleaner left over with nothing else to use it on.
Paul Bernasconi
wa
soarer tt
Saturday, February 25, 2006 - 04:36 pm, by:  Paul Bernasconi (Pauli) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
autosol works good 2.
anything abrasive will work, some products just requre less effort.
correct me if im wrong but i was told the plastic used for lights is petrolium baised and when they dry they start to discolour and crack, to prevent the drying and to prolong the life of the plastic you can rub vasaline ova them after cleaning, hence why a plastic cleaner was invented, to combine both steps
Anish Varsani
V8 UZZ30
Saturday, February 25, 2006 - 06:14 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
KY for your headlights, huh?
Sunday, February 26, 2006 - 10:28 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, helps them gliiiide through the air
Nathan Richardson
UZZ 32 (V8)
Sunday, February 26, 2006 - 03:55 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmmm, the missus knows I like my car, but I don't know what she would do if she found me lubing it up!
Chris James
Soarer V8
Reg: 05-2007
Monday, May 14, 2007 - 08:49 pm, by:  Chris James (Beaupix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi everyone
Have tried polishing & buffing and all of that
but it JUST does Not last.I need to replace the
front headlight lenses.Any ideas or do I have to
re-manufacture. Thanks B.P.
Peter Bullman
SC400
Monday, May 14, 2007 - 09:12 pm, by:  Peter Bullman (Pete) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Providing you (or a previous owner) Hasn't tried to use Thinners Then try using Maguires PlastX..!! Been using for a while now.. I've only had to apply 3 times since December and each time weren't that bad!! (except for when I bought it of course!!)
Good luck!!
Gregg Holden
Soarer UZZ31 Supercharged
Tuesday, May 15, 2007 - 10:43 am, by:  Gregg Holden (Xzotic) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris James wrote on Monday, May 14, 2007 - 08:49 pm:
Hi everyone
Check out the for sale thread - second-hand sets with good finishes come up occassionally...
