  Soarer Central * Trim and Interior * Steering Wheel Replacement Previous Previous    Next Next
Jessica Riley
Sydney
Friday, October 27, 2006 - 02:10 pm, by:  Jessica Riley (Je55yr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably a silly question - but is it possible to put a sports steering wheel on my soarer (the cruise control is attached to the steering wheel)? Or do I need to replace it with the same? The current steering wheel is falling apart...
Daniel Trivuncevic
Friday, October 27, 2006 - 03:54 pm, by:  Daniel Trivuncevic (Madm0nk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes you can replace the current wheel with an aftermarket sports wheel, the only thing you require to keep your cruise control is to buy the boss kit for the wheel which has the cruise control functions on it!
do a search and you will find a few different options you have, like retro-fitting the old cruise, or you could just contactr Jeff Harper who sells these boss kits, well atleast he did!
JunkFilterer
Friday, October 27, 2006 - 04:10 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can also get your steering wheel recovered.
Joe Radisic
Turbo
Reg: 10-2006
Saturday, October 28, 2006 - 08:35 am, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i used a standard boss kit, trim down the plastics on the cruise control base that screws into the column and glue it under the steering wheel.
Yang Luo
vic
soarer twin turbo manual
Saturday, October 28, 2006 - 11:09 am, by:  Yang Luo (Steven) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
any one can link a website that steering wheel has cruise control functions
Murray Gauld
Monday, November 06, 2006 - 10:32 pm, by:  Murray Gauld (Muzzagod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So, being a grey import, what do you look under in the local auto parts shop catalogue, for sports steering wheel hub?
