  Soarer Central * Trim and Interior * A/C vents - Preventing cracks? Previous Previous    Next Next
Tobias Trinks
Friday, November 24, 2006 - 07:01 am, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi. I am about to replace my A/C vents with new ones. Is there anything I can do to prevent them cracking again? I read somewhere that spraying the register in a lighter colour would help, also reinforcing the corners from the rear?
Mark Ribbans
UZZ-031 V8
Friday, November 24, 2006 - 11:36 am, by:  Mark Ribbans (V8gtsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I remember reading somewhere that enlarging the holes they go into slightly may prevent this from re-occuring. (i.e with sandpaper).
I think they expand and crack when they can't expand as much as they want to or something along those lines..
Tobias Trinks
Friday, November 24, 2006 - 11:53 am, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, the heat expands the plastic, the cold air from the aircon cools it down and the holes in the wood aren't big enough. Why can't they just use a better material for the replacement vents?
Phil Gibson
'94 black/black UZZ31
Friday, November 24, 2006 - 11:55 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I put a bead of Araldite (the proper 12hr stuff) around the back of my uncracked vents
Whether it will prevent cracking long-term who knows but it cant hurt...
Lawrence Ostle
tt
Reg: 12-2005
Friday, November 24, 2006 - 12:30 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tobias, I recall reading that the new vents were made slightly differently (smaller?), so that any expansion due to heat could occur without the vent self-destructing.
Tobias Trinks
Friday, November 24, 2006 - 03:09 pm, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Lawrence. That would make sense wouldn't it? Can you remember where you read it?
Norfolk Island
Friday, November 24, 2006 - 04:07 pm, by:  Mike Triggs (Mikeandimah) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wondered if it wasn't possible to have a vinyl "sticker" made up. I restored a cracked vent and it looked great except for around the vent symbols where I masked it off- the paint edge is quite visible. A precut black textured sheet with the white vent symbols to cover the lot would look OK. Better than a cracked vent, anyway.
Mark Paddick
Saturday, November 25, 2006 - 09:29 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Enlarging the hole is the go.
My vents have never cracked and don't look like ever doing so.
When I had it apart it was obvious that someone had gone to a great deal of trouble with a set of new vents.
All the mounting holes have been enlarged and this is no mean effort when you look at the steel sandwich construction of that panel.
This allows much better for the different expansion rates of plastic, wood, metal and anything else that got in there.
The vents are NOT tightened to within crushing pressure either, they are allowed to float a bit.
Tobias Trinks
Saturday, November 25, 2006 - 10:22 am, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Man, my "to do" list is getting longer and longer...
Lawrence Ostle
tt
Reg: 12-2005
Monday, January 29, 2007 - 09:09 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tobias - sorry for delay, just saw your question now. I don't remember where I saw the info on the later vents being different.
Lawrence Ostle
tt
Reg: 12-2005
Tuesday, January 30, 2007 - 02:35 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I did see this though.....
http://www.clublexus.com/forums/showthread.php?t=259423
Lawrence Ostle
tt
Reg: 12-2005
Tuesday, January 30, 2007 - 04:51 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
... and from Clublexus:
"I replaced my cracked register about 2 years ago with a new part but it cracked again. I worked out the reason for cracking is the cold air from the air/cond vent blowing on the dark plastic register frame. In hot weather the plastic tends to expand more than the wooden cutout allows, then the cold air cools it down quickly and the register frame cracks. Before installing a new frame, it could be reinforced from the rear side by gluing strips of carbon-fibre or similar material to the corners where the cracks usually develop. Also, spray painting the register frame a light colour (e.g. silver) will reduce its tendency to expand by heat"
Others suggest reinforcing using fibreglass. Expect Araldite or similar would work as well.
