  Soarer Central * Trim and Interior * Retro fitting electronic steering tilt Previous Previous    Next Next
Kanchana Pathirana
3ltr straight 6
Saturday, January 27, 2007 - 01:07 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi guys did a search but could not find anything useful.
can you retro fit the electronic steering tilt from a v8 to a tt or sc300.
i have got access to the entire steering colomn of a v8 with the steering tilt and want to know can it be done.
if so, can any jo blo do it, and how?
could anyone point me in the right direction?
Saturday, January 27, 2007 - 01:58 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It can, and has been done by Manny and possibly others..........not too much of a drama as I understand it.
Kanchana Pathirana
3ltr straight 6
Saturday, January 27, 2007 - 02:13 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmm some info will be nice, piks, a guide anything
thanks
Active V8 and a Factory Manual XF.
Saturday, January 27, 2007 - 03:10 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can only suggest you search the archives, there may be something in there.
Kanchana Pathirana
3ltr straight 6
Sunday, January 28, 2007 - 01:22 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have and nothing useful.
does anyone have any insight to this. do i need to take off the steering shaft down into the engine bay for this task, or does it involve using my existing steering shaft and just placing the electrical components, brackets and motors.
i know the goo roos and moderators should have some info, anything...anyone...photoes, wiring diagrams??
any info will be appreciated
thanks
Kanchana Pathirana
3ltr straight 6
Sunday, January 28, 2007 - 01:23 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
don you think you can give me a brief overview in what to do?
Sunday, January 28, 2007 - 01:32 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Kanchana, but I've never done anything like that so can't even give you an idea where to start.
Good luck with it though
Monday, January 29, 2007 - 05:12 pm, by:  Daniel Czechowski (Dan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Best thing to do is to take your current one apart, and the one from the V8, see what both look like inside, compare, and replace what is necessary. I presume there would be three wires running negative, positive, and accessory. It would probably be a matter of removing the manual mechanism and installing the little motor. Should be that hard to figure it out even if you're only a little mechanically minded. I wouldn't mind trying that myself or helping you out, out of curiousity, pity we're in different states.
How much did you get that V8 column for? Might be a next item on the agenda for me too lol!
Kanchana Pathirana
3ltr straight 6
Friday, February 02, 2007 - 10:34 pm, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
interesting day i had. my mate, his brother and i attempted to see if we could put the steering tilt in my car...
well we got both steering shafts out (with motors and all) and realised that both were inter-changable with each other...so first problem solved, shaft with motors can be attached.
however when it came to the tilt buttons which power the motors and control them were mind baffling...the wiring??
could not figure it out, we guessed there might be a control module for this somewhere but have no idea where. the wires from the tilt buttons ran up the wiring loom to god knows where
a wiring diagram for this would be really nice, we got so close
Soarer VVTi
Saturday, February 03, 2007 - 12:26 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I always had the impression that there was a control module for the tilting column, possibly connected to the memory function (as in for the steering wheel and the seats in UZZ31s?).
If you get it all nutted out though keep us updated, I'd love to have that function in the car.
Kanchana Pathirana
3ltr straight 6
Saturday, February 03, 2007 - 11:32 am, by:  Kanchana Pathirana (Kan83) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well i forgot to mention i saw the steering control module, but i thought this was just for the signals and power steering and stuff. That module might have the steering tilt stuff or you reckon it will be a separate one??
common guys am just a beginner...aaaaaaaaaar...soo close
should have seen last night while in bed, all i could think about were these wires and how i can make it work. this is going to be doing my head in, but ill keep trying. For the sake of the soarer members hahahah
Hey Neil this cd will have what am looking for, by the way how much
Nik Gacomi
Reg: 05-2006
Saturday, February 03, 2007 - 01:09 pm, by:  Nik Gacomi (Snoopie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the control module for sale.
When I bought my TT the previous guy I had purchased it from did 90% of the conversion but I didn't want the electronic tilt so removed all parts and columns and put it back to standard.
There are a fair few parts you need, I have them all except the steering column itself. I do have the column but it was sawn off at the top so is only good for parts.
If you are interested PM me.
Nik
Steve Anthony De Vos
vic
1JZGTE tt
Monday, February 05, 2007 - 09:46 pm, by:  Steve Anthony De Vos (Sdr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
can you retro fit it with the module Nik? what else is needed? wouldnt want to buy the module and find the loom is different.
Nik Gacomi
Reg: 05-2006
Thursday, February 08, 2007 - 12:40 pm, by:  Nik Gacomi (Snoopie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe the following parts are needed:
Tilt ECU
V8 Steering column
Tilt Controller
Steering wheel plastic surround
Wiring loom that goes from either ECU computer to power source or electric steering column to power source (im not sure where power comes from as the guy who started my car didnt ever power it up).
My understanding from him is you may also need a v8 limited dash cluster so that it is compatible with new steering column.
I have the steering wheel plastics, ECU, wiring loom plugs only,v8 dash cluster, a damaged complete steering column (which must have tilt motor on it to work obviously), and tilt controller all for sale.
Cheers,
Nik
PS Im sorry i should mention i believe the wiring loom may not be required and you may be able to adapt your current TT wiring loom as i have the plugs with wires and colouring, but you would obivously need to connect wires correctly
