  Soarer Central * Trim and Interior * A-pillar pods for tweeters Previous Previous    Next Next
Tobias Trinks
Wednesday, March 07, 2007 - 12:23 am, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are there any customised A-pillar pods for tweeter available? Or is there a better way to install the tweeters in the A-pillars?
Wednesday, March 07, 2007 - 12:48 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Would you be able to fit your tweaters in if you ripped off the mounting for the stock ones and glued yours in place?
Tobias Trinks
Wednesday, March 07, 2007 - 05:33 pm, by:  Tobias Trinks (Toby) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unfortunately not. I am about to get a set of Scan Speak ring radiators which have a diameter of 104mm. These are very good tweeters, but mounting location is crucial. So I would like to install them probably in the A pillars together with a set of 4" mids. I wonder if that would be possible at all?
