  Soarer Central * Trim and Interior * Group Buy Door Pockets Previous Previous    Next Next
Kim Nguyen
Thursday, May 03, 2007 - 03:17 pm, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK Guys, Going to organise a group buy for Door Pockets. Put down your name and what is required. ie trim colour and which side you need, passenger, driver or both?
I'm getting both driver and passenger sides with an additional passenger.
Price will most likely be $275 + post
can't find the old group buy thread though, will have a better look when I'm not at work.
Josh Langerak
Reg: 08-2006
Thursday, May 03, 2007 - 03:35 pm, by:  Josh Langerak (Mr247) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you get a pic up of what is actually being ordered. I assume its to fix the arm rest problem but just to clarify.
Chris Hilton
Reg: 12-2006
Thursday, May 03, 2007 - 03:53 pm, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yah agreed pics would b great
and what colours are available. if possible even a colour pallete.
Kim Nguyen
Thursday, May 03, 2007 - 04:08 pm, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/284/39190.html
http://soarercentral.com/sc-forum/messages/284/35000.jpg
the blue part
but yeah the arm rest basically.
as for colours? the stock factory colours.
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Thursday, May 03, 2007 - 06:03 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just picked mine up yesterday in black (ordered July/August 06) they said they had to make up new ones in Japan???
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Thursday, May 03, 2007 - 06:09 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My old ones (re coloured in black) drivers cracked with no splits in the vinyl and passenger no cracks or splits with black speaker grills will be up for sale when removed and checked. Cheers
Daniel Trivuncevic
Thursday, May 03, 2007 - 07:42 pm, by:  Daniel Trivuncevic (Madm0nk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how much Joe?
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Thursday, May 03, 2007 - 10:57 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much for new or old??
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Thursday, May 03, 2007 - 11:07 pm, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New i was quoted Over $400+gst each from Castle Hill they said they went up a lot since last group buy and couldn't do any cheaper. Unless some of you guys can pull some strings. I paid $350+ gst ea they originally quoted as above as a trade price, i ordered them anyway.
I'll work out a price for the old ones when removed and checked over.
Stewart Booton
uk
soarer UZZ31 V8
Friday, May 04, 2007 - 02:45 am, by:  Stewart Booton (V84) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you can get them for £109/$265aud in the UK? may be worth having a word with this supplier??
http://www.toyotalexusspecialists.co.uk/index.php?act=viewProd&productId=125
Joe Radisic
2JZ GTE & TO4Z
Reg: 10-2006
Friday, May 04, 2007 - 07:41 am, by:  Joe Radisic (Joe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What can i say business is business!
Joel Moore
91 Soarer TT
Reg: 10-2006
Tuesday, July 24, 2007 - 08:13 pm, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is anyone keen on a group buy for these, i am going to buy a drivers side soonish.
Spencer Skett
Tuesday, July 24, 2007 - 09:28 pm, by:  Spencer Skett (Spenq) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm interested - I need both sides
Christian Molenda
T
Wednesday, July 25, 2007 - 07:29 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
why not repair and get them strengthened. Then have them re-trimmed. Im sure that will be alot cheaper than $800. (400 per door)
after all the new ones will break again some day and with the price of soarers these days, it would be hard to justify spending over $400 per door
Keenan Edinger
UZZ31 GT-L V8
Wednesday, July 25, 2007 - 02:32 pm, by:  Keenan Edinger (Keenan585) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If they are still at $275 each Kim I would definitely be in for a drivers side one in spruce/light grey. Would be able to pick it up off you too. Keep us up to date mate, cheers.
Kim Nguyen
Monday, July 30, 2007 - 03:04 pm, by:  Kim Nguyen (Kim) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well the interested died in the proverbial ass so I left it for a while.
But seeing that Spencer, Joel and yourself Keenan that would give me the 5 required for a group buy.
I will put the enquiry through again, can you please provide me with your trim colour please?
So it looks like
Me: Both sides
Joel: Driver side
Spencer: Both sides
Keenan: Driver side
Keenan Edinger
UZZ31 GT-L V8
Monday, July 30, 2007 - 06:27 pm, by:  Keenan Edinger (Keenan585) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry guys, I might be getting mine recovered now, just checking out which way will be the cheapest. Sorry!
Joel Moore
91 Soarer TT
Reg: 10-2006
Saturday, August 04, 2007 - 06:07 pm, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ill take both sides to make up numbers, when do i have to pay by? maybe some of the traders are interested in getting some as well??
Murray Allen
Monday, August 06, 2007 - 05:27 pm, by:  Murray Allen (Rusty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a brand new unused right hand side door pocket in spruce. I paid $290 for it inc shipping. I'll let it go to anyone who wants it for the same price
Blake Dobe
Reg: 07-2007
Monday, August 06, 2007 - 06:34 pm, by:  Blake Dobe (Space_midgit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey mate I need to know when you plan on ordering these puppies also does the $275 cover both doors, I should have cash this thursday coming, 9 Aug 07
Joel Moore
91 Soarer TT
Reg: 10-2006
Tuesday, August 07, 2007 - 05:00 pm, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
blake 275 is one door trim.. they are expensive due to the design and shape and the fact they are leather
Joel Moore
91 Soarer TT
Reg: 10-2006
Tuesday, August 07, 2007 - 05:01 pm, by:  Joel Moore (Ttsoai2ei2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lets kick this group buy off, more will come.
Blake Dobe
Reg: 07-2007
Thursday, August 09, 2007 - 08:58 pm, by:  Blake Dobe (Space_midgit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I should be in, I just need to get in touch with my brother seeing as its his car and money. Next fortnight Would Be Ideal.
