  Soarer Central * Trim and Interior * Help with dropping rear window cover. Previous Previous    Next Next
Ed & Tim Uhen
Reg: 01-2007
Sunday, November 25, 2007 - 09:10 pm, by:  Ed & Tim Uhen (Zzt231) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello All,
From an importer we got a rear window cover that was from a Soarer. It's a sheet of plastic with lines on it shaped of the rear window and is inserted behind the glass. I know it's an OEM part as it's got the Toyota sticker but don't have any part numbers for it.
Problem is that the cover keeps on dropping off as sort of wedged into place. As anyone have similar problems and know how to over come it? It's driving me nuts as it drops down occasionally and there is no visible sign of double sided tape used when it was in the previous car.
Cheers.
Dave Rose
wa
uzz31 v8 97
Sunday, November 25, 2007 - 10:18 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ed & Tim
The panel is held in place with 4 clips its a sun shade ...double glazing unit
Ed & Tim Uhen
Reg: 01-2007
Monday, November 26, 2007 - 12:10 pm, by:  Ed & Tim Uhen (Zzt231) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello Dave,
That's the one... Could you take a photo of those clips closer? You wouldn't know if if the part number is on it?
Cheers.
Mark Donovan
Wellington
Soarer V8 Limited
Monday, November 26, 2007 - 03:50 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I sold mine once I tinted all the windows. It's more trouble than it's worth.
Dave Rose
wa
uzz31 v8 97
Monday, November 26, 2007 - 11:15 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Will take a photo soon as i can...regards Dave
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Thursday, November 29, 2007 - 03:14 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just tint, it'll look better anyways, IMO.
Ed & Tim Uhen
Reg: 01-2007
Thursday, November 29, 2007 - 12:26 pm, by:  Ed & Tim Uhen (Zzt231) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would like to put the sunshade as I don't want to tint the windows...
Dave Rose
wa
uzz31 v8 97
Thursday, November 29, 2007 - 06:12 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry no part # on clips heres a pic
