  Soarer Central * Trim and Interior * Need Help (window regulator???) Previous Previous    Next Next
Chris Dmochowski
Toyota UZZ31 GTL V8
Reg: 06-2007
Monday, December 03, 2007 - 01:24 am, by:  Chris Dmochowski (Mr_chrisdmo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey all I need help with my window my car is a 1992 UZZ31 GTL V8 Soarer
Well driving home today I decided to open my drivers side window when half way down it made a crack noise and stopped working I pushed the button and it started to make a noise like removing a video from a VHS player(electrical noise)then by the time i got past the next roundabout the window had fallen in to the door. I got home and tried to use the button to pull the window up it got about half way up then stoped I tried once more and it started to make the same electrical noise...
do any of you guy know what it may be..window regulator,window regulator assembly,regulator motor
Gary Redman
Wednesday, December 19, 2007 - 12:37 pm, by:  Gary Redman (Gary) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can bet the plastic slide on the regulator has broken. This is attached to the cable and also holds the glass in position when going up and down. You can still hear the motor because it will still move the cables up and down, but the cable is attached to the plastic that breaks. And you can't buy the plastic piece, you have to get another regulator.
John Khanh
Limited V8
Wednesday, January 09, 2008 - 09:20 pm, by:  John Khanh (Bigjohn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, need to get a new regulator.
If you can't get the window up, you can pull it closed by hand. It'll get to a point where you can't pull it up anymore. Just press the button up or down a tiny bit, then you can manually pull it up again.
