Saturday, May 24, 2008 - 10:30 am, by: Rob Rojo(Rob_tt)
I am not going to be doing my leather as its pretty stuffed , I am Buying full leather covers for my seats its the same as having a retrim for a bit over $500 easily beats paying $1800.
Sunday, May 25, 2008 - 07:29 pm, by: Chris Prak(Carizma)
I used Motorspray for the centre compartment/armrest part. It did soak in pretty well, but after a quick wipe with armorall, it slightly faded off a tiny bit (have to really look close), so I backed away. VHT had no problems when using armorall on it.
Danny Novosel TryHard SA 2x UZZ31 Ltd, EVO 4 GSR, 06 Hiace
Sunday, May 25, 2008 - 09:22 pm, by: Danny Novosel(Dtheman)
Again as stated, It must be prepped and primed using leather wash with dye it, No it doesn't come off unless you are stupid and get some sandpaper or something, The first thing i did was just spray the centre console using motorspray and even with 5 coats it just came right off when i cleaned it. YOU MUST USE A PRIMER.....
Sunday, May 25, 2008 - 09:33 pm, by: Rob Rojo(Rob_tt)
I don't know about the motorspray, but the VHT is not meant to be put on heavily & no primer to be used as it is supposed to be sprayed only until desired colour is reached (2 coats or so), primer will just stop it penetrating the vinyl. You just have to make sure it is cleaned thoroughly before spraying.
