David Tra wrote on Tuesday, August 19, 2008 - 04:30 pm:
by contacts you mean the white plug?
if so, then no, there is no build up. Looks pretty clean.
thanks for that Alan
I think he means contacts in the switch itself, not the plug. i would get some electrical contact cleaner, pop the switch off and spray the contacts and inside with it. that will probably fix the problem
Wednesday, September 03, 2008 - 02:15 pm, by: Michael Crimp(Zen1953)
I haven't read the whole thread but: I have a suggestion which works for me (for free lol) when the electrics of my Merc play up. I spray the switches and contacts with WD 40 penetrating solution and sometimes they miraculously function for a while. If it doesn't work from there then take an electrical multi metre $20-$30 from Dick Smiths switch it to 20v and test the wires and switches to find out where the electrical current stops and there you should have the problem isolated. You may have to have someone work the switch while your testing the circuit. Good luck
Wednesday, September 03, 2008 - 04:41 pm, by: Alan Chow(Alanchow)
by contacts i mean the pieces of metal that touch when you push the switch. They usually blacken over time and hence stop working. i fixed mine by scraping of the black carbon. you can also get cleaners for it but meh.
