  Soarer Central * Trim and Interior * Removing uzz31 steering wheel Previous Previous    Next Next
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, January 21, 2009 - 01:08 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys, my horn and cruise control have just stopped working so I want to take out the center of the wheel to check the connections.
I've looked through the "Steering wheel removal" tutorial but the screws I need to remove are not on my wheel. Is that tute only applicable to the uzz30?
Can anyone please tell me how to take it off, and will disconnecting the battery stop the airbag from rearranging my face should it be tripped?
Rob Andreacchio
I've sprouted horns!
Reg: 01-2005
Wednesday, January 21, 2009 - 01:54 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you need to loosen those ones you highlighted.. and you'll need a special screwdriver to do it
Wednesday, January 21, 2009 - 02:15 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think the pics with arrows are from the tutorial, the other pics show his column without the screws.
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, January 21, 2009 - 02:41 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats right Peter, sorry I probably should have written that.
What steps do I need to take to disable the airbag?
Dave Rose
wa
uzz31 v8
Wednesday, January 21, 2009 - 02:41 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
also leave the wheel nut on the last few threads when you try to pull it off , as they can rearrange your teeth....(you may need a puller)
Rob Andreacchio
Reg: 01-2005
Wednesday, January 21, 2009 - 02:53 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
old trick... bang the fark out of the wheel and pull.. bang and pull.. eventually it will move! lol
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, January 21, 2009 - 03:06 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is that before or after I loosen up those bits Rob? hahaha
Most of the fixes I do with this car end up being done with that method.
Rob Andreacchio
Reg: 01-2005
Wednesday, January 21, 2009 - 04:28 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL after.... you'll need to remove them to get the airbag off.. then unplug the airbag... then youll see the big nut to loosen....
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, January 21, 2009 - 09:37 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I disconnect the battery terminal can the air bag still go off?
Rob Andreacchio
Reg: 01-2005
Wednesday, January 21, 2009 - 09:40 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no.. your safe if its unplugged... but i removed it a few times with it all intact and i still here hehehe
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, January 21, 2009 - 09:43 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah you see but your on 3206 posts, and i'm only on 335. Which means the odds of it happening to me are 10 times greater...
Blake Davies
S A
Factory 5sp TT
Wednesday, February 04, 2009 - 11:56 am, by:  Blake Davies (Boss_da_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey mate if you have an airbag equipped soarer would you be able to take a picture.
I'm just trying to find out where a spare wire might plug into on my car.
Alex Barbieri
V8 GT-L
Reg: 08-2007
Wednesday, February 04, 2009 - 06:13 pm, by:  Alex Barbieri (Barbieros) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What colour is it?
