  Soarer Central * Trim and Interior * Does a steering wheel need to be adr approved? Previous Previous    Next Next
Paul Bell
Reg: 08-2009
Thursday, October 22, 2009 - 09:12 pm, by:  Paul Bell (Bello) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So i've got a new steering wheel for my soarer and i was just alittle concerned about getting defected for it if i'm pulled over.
I read here
http://www.infrastructure.gov.au/roads/motor/design/pdf/ADRApplicabilitySummary_M_GroupSeptember2009v1.pdf
and there's no mention of the steering wheel having to be adr approved, just the steering column and my boss kit is adr approved.
So am i right in thinking there is no legal issues with fitting my aftermarket steering wheel?
Thursday, October 22, 2009 - 10:42 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, It has to be a minimum size mate . I think 330mm diameter is minimum size ( check your local rta website ).
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Friday, October 23, 2009 - 10:27 am, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah or if you have to change the steering wheel hub you need that approved. The one that's in the 260z we're building has to get approved before we put it on.
Gary Redman
Friday, October 23, 2009 - 11:57 am, by:  Gary Redman (Gary) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You probably can't replace an air bag wheel with a non air bag one
Paul Bell
Reg: 08-2009
Friday, October 23, 2009 - 06:00 pm, by:  Paul Bell (Bello) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks all, the steering wheel is 350mm and the hub kit is adr approved so it sounds like i'm good to go :-)
JZZ30 2JZ + Manual
Friday, October 23, 2009 - 06:38 pm, by:  James Johnson (Jamesy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
and you need padding on the center so your head doesn't split open thats your main problem for legalities
Paul Bell
Reg: 08-2009
Friday, October 23, 2009 - 08:35 pm, by:  Paul Bell (Bello) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks, is there anywhere on the interweb i can see this info on an officail website? \
GT Starlet
Friday, October 23, 2009 - 09:40 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Who woulda guessed ALL can be found at the Queensland Transport Website?
Steering wheels
Altering a steering wheel might affect a vehicle's
compliance with the Australian Design Rules (ADRs)
applicable to occupant impact protection.
Steering wheels fitted to vehicles manufactured to
comply with ADR 10/.. may only be replaced by a
steering wheel which has been tested to comply with
ADR10/... Where these ADRs apply, the vehicle's steering
column and steering wheel are designed to minimise
injury to the driver in the event of a crash.
Vehicles that are required to comply with ADR 69/.. or
ADR 73/.. or where originally fitted with a driver airbag
must not be fitted with a replacement steering wheel
without an airbag, unless it is supplied by the vehicle
manufacturer as an option for that model.
The diameter of any replacement wheel may be up to
25mm smaller than the original wheel but must not
be less than 350mm.
But really, at the end of the day common sense applies mate, just dont install some welded chain from Mad Max and i dare say you will get away with it. Police have bigger fish to fry such as their battle against PTTCCHHHHHHHH making devices haha
Paul Bell
Reg: 08-2009
Friday, October 23, 2009 - 10:15 pm, by:  Paul Bell (Bello) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lol sooo true, i'm really just trying to get my head round all this car modifying red tape, being a pommy immigrant i've been spoilt by having zero rules on car modifications.
I've read the bit you've posted quite a few times now during my searching for the answer, are aftermarket items stamped with some kind of adr code then? such as a steering wheel having the code adr10/00 and hub kit adr00/01?
think you're probably right though, i should stop being such a dick and just fit it and not worry about it.
GT Starlet
Saturday, October 24, 2009 - 12:30 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not sure if they are stamped as such but i would assume they are...
I would doubt very much that the sparco wheel is ADR but i wouldnt really worry about it too much mate, there are only a few steering wheels getting around that ARE ADR'd... some Autotechnica, some OBX, there is a list of them ONLINE if you are really keen.
Yup just bolt it on mate and enjoy the sparco goodness like i do when i sit in my lovely Sparco Torino seats!
David Grab
T78
Reg: 01-2008
Sunday, October 25, 2009 - 03:14 am, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wheel has to be ADR to be legal. Only all MOMO wheels are ADR complied, a few autotechnica whatever but they look terrible. Cops will notice it, well in SA they would atleast. Mainly the issue is that the wheel doesnt bend/snap during an impact. The main issue for me would be insurance, in the even of an accident you might not get a pay out with the sparco wheel and also if your injured and cant work you might not be able to get compo.
Also if your coming from a factory airbag steering wheel you cant downgrade to a non airbag steering wheel no matter if it is ADR approved.
