  Soarer Central * Trim and Interior * Ball on dash Previous Previous    Next Next
Haydn Crandell
TT 2.5
Sunday, December 11, 2005 - 10:33 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does anyone know what the little dome ball thing is on the passenger side of the dash is?located the same as the auto light sensor on the drivers side, only opposite
Sunday, December 11, 2005 - 10:48 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sensor for fast air conditioning response to changing sun/cloud/tunnel conditions
Haydn Crandell
TT 2.5
Sunday, December 11, 2005 - 11:07 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
looks just like a wooden ball!!!dam how many things are there for air cons?there is that, then the sensor under the front bar, then the little grille square thing inside right hand side of console
Haydn Crandell
TT 2.5
Sunday, December 11, 2005 - 11:28 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
while your at it what is the other vent looking thing on the passenger side under the glove box?about the size of your little pinky(that being your finger) lol
Monday, December 12, 2005 - 11:09 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There are four sensors for the Air Con. The fourth measures the temperature of the evaporator.
I have no idea what that little vent on the left is for. It looks designed to flow a small quantity of air and its interior passage seems to be padded. I did not see it listed on diagrams for the Air Con or the audio (clutching at straws) system. A separate sensor for the air purifier?
Super Charged UZZ31
Monday, December 12, 2005 - 01:03 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its to check *Cabin Humidity*
Monday, December 12, 2005 - 01:21 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So, if it decided the air was too dry, what would it do about it? Let in more unfiltered Aussie summer desert air? Spray radiator coolant into the cabin?
JunkFilterer
Monday, December 12, 2005 - 01:26 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it detects sweaty passengers and slows the car down :-)
JunkFilterer
A little like the whining noise that sometimes comes from the passenger seat area.
Super Charged UZZ31
Monday, December 12, 2005 - 01:40 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Piss into it :-)
Ollie Ernst
Soarer V8 Limited
Monday, December 12, 2005 - 02:42 pm, by:  Ollie Ernst (Oli_g) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil Griffiths wrote on Monday, December 12, 2005 - 01:40 pm:
Piss into it
Note to self - Don't top up ALL fluid levels.
1991 UZZ30 GT4.0 V8
Monday, December 12, 2005 - 03:17 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
