Wednesday, June 02, 2010 - 08:11 pm, by: Ben Lipman(Ben12a)
Yeah mate you will. The purpose of the boss kit is to give you something to bolt the wheel to. It sits on the end of the steering column on a splined shaft, and then the wheel is bolted to it.
Once you remove the factory horn pad it becomes crystal clear.
By not needing cruise control, you should save yourself some dollars on the boss kit, or you could use the three buttons for some other function (volume control, spotties, neons- whatever takes your fancy.)
Warren Moore TryHard Victoria MiGoreng JZZ31 @ 999rwkw
Wednesday, June 02, 2010 - 09:04 pm, by: Ben Lipman(Ben12a)
That'll do the job. I don't know what a good price would be, but that is a helluva lot cheaper than the cruise control one I got in the group buy on here.
