Sunday, April 10, 2011 - 04:34 am, by: Jimmy Au(Bored)
Hi guys Was wondering if someone can help me with this problem. I recently installed a set of bride seats and because they're not electric the seat belt light stays on all the time. Is there are pin out for the plug underneath the seat to disable this
Tuesday, April 12, 2011 - 08:59 am, by: Vincent Chan(Vincent191)
Check the seat belt buckle. The original has a wire coming out of it. I guess that tells the car if the seatbelt is fasten or not. Mine came loose and the seatbelt light stayed on. I had to remove the front seat to fasten the wire back onto the buckle.
Saturday, May 28, 2011 - 11:21 pm, by: Ross Bull(Roscoe)
I had this problem when I first got my Soarer.
There was a couple of wires going to the seat belt buckle under the seat, I bridged these two wires to stop the warning light. (this involved pulling out the drivers seat to access the wiring)
Sunday, May 29, 2011 - 03:40 pm, by: Brett Harrison(Bretto)
Theres a little orange plug, has two wires. This plug's into the original seat buckle. When car is complied they usually just bridge the plug as Ross said.
If you have aftermarket seats, bridge the wires at the main plug, not sure of colour codes, but a paperclip, and a few minutes should figure that one out.
