  Soarer Central * Trim and Interior * How to Remove Center Console? Previous Previous    Next Next
Kristoph Schneider
Soarer UZZ31 V8
Reg: 11-2007
Wednesday, May 25, 2011 - 03:47 pm, by:  Kristoph Schneider (Kristoph) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys just wondering where all the screws are that are holding all the center plastic down?
As highlighted.
I've got everything else out, the EMV, the shifter and the woodtrim around it but the center glove box seems pretty solid in there.
Kristoph Schneider
Soarer UZZ31 V8
Reg: 11-2007
Wednesday, May 25, 2011 - 04:44 pm, by:  Kristoph Schneider (Kristoph) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Update:
I found the bolts under the cover inside the center console box but it seems to be still stuck in where the EMV is near the driver\passenger knee area.
Ali Saeed
Wednesday, May 25, 2011 - 06:27 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
from memory i think there are some in the foot well too, on the left of pedals, you should be able to see it.
Kristoph Schneider
Soarer UZZ31 V8
Reg: 11-2007
Thursday, May 26, 2011 - 04:52 pm, by:  Kristoph Schneider (Kristoph) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah cheers got them :-) theres one next to the break pedal and the other requires the glove box to be removed, what a hassle!
