  Soarer Central * Trim and Interior * How to remove electric controls from side of drivers seat Previous Previous    Next Next
Joseph Kelly
N.S.W
Reg: 09-2012
Thursday, March 28, 2013 - 07:33 pm, by:  Joseph Kelly (Phenonix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How do i removes the buttons and plastic covering on the side of the drivers and passenger seat?
Painting my seats so i want to removes these to do a good job on the leather
Thanks
Robert Faggian
Reg: 02-2009
Thursday, March 28, 2013 - 09:26 pm, by:  Robert Faggian (Tanooki_suit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its a real pain. There is a metal c-clip at the base of the lever (underneath the plastic cover) that you need to remove before you can take the plastic cover off...its hard to get at and even harder to put back later. The other buttons just pop off.
Shane Haverkamp
soarer TT
Reg: 10-2007
Friday, March 29, 2013 - 03:11 pm, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if i remember correctly as rob said its a c-clip on the handle
but its a bit tricky to get off as its more a spring design
you kind of need to spread the thing apart on both sides. you can try one edge at a time but it generally just rocks the other edge back into groove
my drawing kind of shows what i mean with the red being the c-clip and the black being the shaft on the seat.
Joseph Kelly
N.S.W
Reg: 09-2012
Friday, March 29, 2013 - 05:10 pm, by:  Joseph Kelly (Phenonix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks, had a look and i can see that clip, wondering now if i'll just paint around the plastic?
Scale of 1 - 10 how difficult is it to get back in?
