  Soarer Central * Trim and Interior * Centre Air Vent Previous Previous    Next Next
Craig Moore
V8 Uzz31
Thursday, April 27, 2006 - 09:23 pm, by:  Craig Moore (Craig) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Has anyone repaired the cracks in the centre and side dash air vent surrounds? I want to repair if it's possible mine and am wondering if anyone is aware of a tutorial (showing removal steps and repair details) or do I just replace the sucker?
Darryn Dewar
Gisborne
UZZ30 Soarer
Thursday, April 27, 2006 - 09:31 pm, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd prefer to replace it myself.....but good luck finding a decent one
Joe Aliano
Nsw
91 UZZ31 Soarer , 2004 CV8-R Monaro
Thursday, April 27, 2006 - 09:53 pm, by:  Joe Aliano (Sexylexus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If I could have found one I would have replaced mine but as Darryn said good luck in finding one.
However I did repair mine using Bostik Titan Bond part A & B ..I found it quite good as it flexes with the shrinkage that occurs. It needs around 12 hours for it to set properly so I used a bull dog clip to hold it in place over night.
Michael Howatt
4.0 GT-L - V8 - UZZ31
Reg: 12-2005
Thursday, April 27, 2006 - 10:03 pm, by:  Michael Howatt (Howatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Darryn, the post that you mention on Reepa's site does not tell you how to fix up the vent. It tells you how to remove the vent.
Darryn Dewar
Gisborne
UZZ30 Soarer
Friday, April 28, 2006 - 08:16 am, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Michael, You're right.....but in all honesty getting the vents out is the hard part, if you need a tutorial to glue a cracked piece of plastic then I would recommend finding someone else to do the job.
A better discussion would be about what products people have used and the results they got.
Friday, April 28, 2006 - 02:26 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From memory, if ya do a search, someone did a thread about how they repaired the cracked center vent, but I can't for the life of me remember when or who.
Craig Moore
V8 Uzz31
Friday, April 28, 2006 - 05:22 pm, by:  Craig Moore (Craig) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well that's the info I am after, (what glue).
I can pull the car to bits (been there) but glueing plastic with the CORRECT glue is the difficult bit.
Friday, April 28, 2006 - 06:50 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Craig, off topic, but your mailbox is full.
Ben Socratous
JZZ30 GT-TL
Friday, April 28, 2006 - 08:03 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK Mr anti lazy typing and punctuation nazi, your mailbox is FULL, hehehehehe.
Also guys, most epoxy resins (2 part glues) will work well on plastic. Steer away from cynoacrylite based products (superglue) as they tend to leave a nasty white stain. At least if you're going to use that, just make sure your intern isn't wearing a black dress...
Joe Aliano
Nsw
Friday, April 28, 2006 - 09:09 pm, by:  Joe Aliano (Sexylexus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Craig Moore wrote on Friday, April 28, 2006 - 05:22 pm:
I gather you missed when I said the following
Joe Aliano wrote on Thursday, April 27, 2006 - 09:53 pm:
UZZ32 ( V8 )
Saturday, April 29, 2006 - 08:46 am, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Go down to a sign manufacturer of a plastic fabrication place and buy/scab some glue called acrifix. Superglue will join the crack instantly but for god's sake do not let it run onto the showface. It will leave a white residue. The acrifix is an awesome product to squirt onto the back of the vent to build up the vent's strength. Done it to mine about 2 years ago. Still good today.
Saturday, April 29, 2006 - 09:57 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My vents are unbroken AND original
Sorry, just thought I'd SHARE!
UZZ32 ( V8 )
Saturday, April 29, 2006 - 10:27 am, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have an unbroken spare too Don.
Saturday, April 29, 2006 - 10:50 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HaHa!..........It'd be worth GOLD Pez.
But knowing your luck if ya flogged it, your in-car one would explode into a zillion bits shortly there after
UZZ32 ( V8 )
Saturday, April 29, 2006 - 11:43 am, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got spare emv's, computers, fuel ecu's, emv's, you name it. I'll never need any while I own the car but as you say, the second after I sell one mine would die for sure haha.
Saturday, April 29, 2006 - 12:27 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Perry = Parts Magpie. :-)
Saturday, April 29, 2006 - 12:59 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or "Kea" in his case
Oh, and Pez, ya mentioned EMV's TWICE.........does that mean ewe's have got double the amount you thought you had? Hmmmmmm!
UZZ32 ( V8 )
Saturday, April 29, 2006 - 01:21 pm, by:  Perry Morgan (Uzz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ooops. Well does 2 and a 1/2 all up count then?
Saturday, April 29, 2006 - 04:04 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Craig Moore
V8 Uzz31
Saturday, April 29, 2006 - 05:28 pm, by:  Craig Moore (Craig) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks to all for the glue info (I did see your post re Titan Joe).
Peter "My mailbox is Full" What mailbox?
Saturday, April 29, 2006 - 06:29 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Craig, your PigBond email address that gets email notifications etc.
"The user(s) account is temporarily over quota"
Been like it for weeks, and I have to delete all the bounce messages.
Craig Moore
V8 Uzz31
Saturday, April 29, 2006 - 08:36 pm, by:  Craig Moore (Craig) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Pete but I ditched PigPond several weeks ago and changed to AdamandEve.com. I also updated my profile here to reflect my new email so I don't know why Pigpond is bouncing messages???? Yehhh, been waiting weeks to use this icon...hahahaha
Saturday, April 29, 2006 - 08:49 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK, I have updates the system address database too. There are 2 places to edit your email address in the profile. All fixed! :-)
Now you will get bombarded with notifications and PM's again :-)
Lawrence Ostle
tt
Reg: 12-2005
Sunday, April 30, 2006 - 04:22 pm, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is a bunch in Qld called Cresta - i bought a set of vents from them 2nd hand, they may be worth a try.
