  Soarer Central * General Soarer Chat * What I have been upto this week3 (LSD) Previous Previous    Next Next
Raj Somarouthu
Scotland
Soarer V8
Reg: 07-2009
Monday, November 16, 2009 - 03:14 am, by:  Raj Somarouthu (Edinlexusv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Been doing some work on my diff to swap the centre with a torsen LSD from a supra. I put up this thread to update you all about this and possibly get some advice if I get stuck. But I am stuck at step 14
SA100 - 14. Check Minimum Backlash
Any advice would be very much appreciated!
Started off by pulling the diff out. The one highlighted in yellow is the one I bought for this conversion. It is a post 1997 Supra TT diff centre which is 8" (same as the soarer diff centre). As I will be using the same crown wheel and the pinion, the teeth being 47 and 12 respectively the final gear ratio would remain the same as 47/12 = 3.917
Raj Somarouthu
Scotland
Soarer V8
Reg: 07-2009
Monday, November 16, 2009 - 03:17 am, by:  Raj Somarouthu (Edinlexusv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now coming to step 14 in the tutorial, I need to do shimming and find the right shim to fit in the LSD so that there will be minimum backlash. (SA100 - 14. Check Minimum Backlash) No idea how to get this done???
Monday, November 16, 2009 - 06:08 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry I can't help with any advise, but just wanted to say great photos!
Raj Somarouthu
Scotland
Soarer V8
Reg: 07-2009
Monday, November 16, 2009 - 06:26 am, by:  Raj Somarouthu (Edinlexusv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Matt, will get it sorted on monday!
Raj Somarouthu
Scotland
Soarer V8
Reg: 07-2009
Thursday, November 19, 2009 - 01:59 am, by:  Raj Somarouthu (Edinlexusv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Some final pics of the diff rebuild folks,
After a lot of scrubbing with awire bush and generous use of hammerite!
Measuring the backlash with the guage
Diff rebuild is complete and is ready to go back onto the car
Paul Bell
Reg: 08-2009
Thursday, November 19, 2009 - 08:57 pm, by:  Paul Bell (Bello) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good work, looks nice and sparkly clean! You'll love driving with the torsen diff in, it really completes the car as a package! why they didn't all come with one standard from the factory beggars belief..
Raj Somarouthu
Scotland
Soarer V8
Reg: 07-2009
Friday, November 20, 2009 - 07:49 am, by:  Raj Somarouthu (Edinlexusv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I totally agree with you. V8 soarer should have come with an LSD and decent size Supra brakes or at least the TT brakes out of the factory. Everybody seems to do these upgrades anyway.
