  Soarer Central * General Soarer Chat * How long is too long? Previous Previous    Next Next
Kadir Hussein
SC400 Limited
Reg: 12-2009
Monday, January 04, 2010 - 10:10 pm, by:  Kadir Hussein (Khuss888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought my Soarer, sight unseen about a month ago. It will probably be another month before I return to Melbourne to drive it, and eventually truck it over to WA.
I'm getting nervy about it sitting so long unstarted. I had mum try to start it up this evening and it's flat (interior light on!)
Is this going to cause problems for the car?
Ian Johnston
UZZ30 GT 4.0, UZZ31, BMW R1150R
Monday, January 04, 2010 - 10:45 pm, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
May pay to get someone to disconnect the battery until you are ready to drive it.
I parked my UZZ31 for a couple of months, and thats what I did.
Miles Baker
66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 69 Nova SS Clone, 65 Mustang Fastback, 67 Mustang Convertible, 67 Camaro RS/SS
Monday, January 04, 2010 - 11:08 pm, by:  Miles Baker (Milesb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I left mine sitting for 18 months. Dropped in a fresh battery, started right up. They do suck up a battery in a few weeks.
Kadir Hussein
SC400 Limited
Reg: 12-2009
Tuesday, January 05, 2010 - 01:30 pm, by:  Kadir Hussein (Khuss888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks, I feel better about it now. I'll get the battery disconnected.
Nathan Machin
Soarer 3.0L non Turbo
Reg: 06-2009
Wednesday, January 06, 2010 - 12:52 pm, by:  Nathan Machin (Nthside_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kadir mine has been sitting in my garage not driven for a few months now, im waiting to get it painted. I drained the battery without starting it, but i charged the battery and it started first try and almost instantly with no hassles at all mate.
you should be fine bro
Ben Daniel
UZZ31 & JZA80
Wednesday, January 06, 2010 - 08:15 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've heard of people who are not using their cars for long periods of time that they put it up on car stands to aid the suspension.
Kadir Hussein
SC400 Limited
Reg: 12-2009
Wednesday, January 06, 2010 - 09:29 pm, by:  Kadir Hussein (Khuss888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mind you the previous owner imported the car 7 years ago and never registered it. So if you think about it, it's probably done its fair share of sitting around.
I suppose you just get paranoid about relatively big investments, especially when they are still new (to me) :-)
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Thursday, January 07, 2010 - 06:34 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it might run a bit rough on first start up if you take the battery out, but it will be fine.
Nina Smart
QLD (Gold Coast)
SC400 & GT4 & NX
Reg: 10-2009
Friday, January 08, 2010 - 02:33 pm, by:  Nina Smart (050ara) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am in the same boat. About to get stand this weekend for her... Battery is out.
She has been sitting for about 4 months now. As Steven said, mine ran a bit rough whenever I started it up for a quick run but cleared up after a bit.
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Saturday, January 09, 2010 - 05:28 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just started a 1jz which had been sitting without oil for 8 months and not turned over for another 4 before that. although i manually cranked it over first a few times to make sure it moved alright.
its in the 260z
i'll make a post about it later when its running properly. probably about 2 weeks from now it'll be driveable :-)
