Michael Brown
TryHard Queensland V8 UZZ31 Limited, Ralliart Magna, Holden Camira
Posts: 244 Reg: 07-2009
| Hey guys last nite i learnt the hard way of towing a Soarer behind a car. My genious mate decided hed tow my Soarer behind his car everything was going well i had the key turned on with the engine turned off. Steering was heavy but i could handle it. got up to 60kms per hour then i went to tap the brakes and realised they wouldnt work i pressed the brake pedal as hard as i could and nothing happened unfortunatly the car slamed into the back of my mates car. :'( luckly appart from a few bruises and some wiplash we are both ok. Because my cars so low it went under the back of his Kia Rio and damaged the top of my front bar and bonnet. So i send a warning to all people who intend on towning a Soarer illegally . DONT DO IT!! Pay for a tilt tray!!! haha |
Aaron Casey
Goo Roo nsw '94 jzz30 gttl, 2 mini's one supercharged
Posts: 1730 Reg: 08-2005
| oh crap thats no good i always check braking before i flat tow them if not use the handbrake but dont go very fast. Was there alot of damage or few scrapes and dints? Hope it doesnt cost too much to fix. |
Posts: 11242 Reg: 11-2004
| The brakes do work, just not very well without the power assistance. TRC brakes will work normally as long as the ignition is on. |
Michael Brown
Posts: 245 Reg: 07-2009
| when i first took off they were working but after about 5 mins of towing i went to check them again and they didnt work at all ! I pressed as hard as i could and nothing happened . the key was turned to on but the engine was turned off. My handbrake wasnt working very well and i only had a split second to respond. And the damage is fixable just gotta get a new front bar and bonnet. And straighten the headlights cos the front bar moved them. front bar is split and not lookin the best and the bonnet is bent and dented. Ill be fixing it all myself so hopefully it doesnt cos to much to fix. I mite finally get the Vertex ridge kit ive always wanted haha. First car accidents are always the scariest. |
Damian Ware
Goo Roo Victoria UZZ32
Posts: 1298 Reg: 10-2005
Michael Brown wrote on Monday, January 18, 2010 - 09:47 am:So i send a warning to all people who intend on towning a Soarer illegally . DONT DO IT!! Pay for a tilt tray!!! haha
It is legal to tow a car behind another via a rope chain ect. And the brakes will still work without power assist it just requires a lot of effort to push the pedal. |
Austen Menze
TryHard WA GT-TL
Posts: 344 Reg: 07-2009
| Damn I hope it doesn't cost you too much, do you have pics? I'm amazed the Kia has enough balls to tow a Soarer! |
Michael Brown
Posts: 246 Reg: 07-2009
| really ? i thought it was illegal. And it wasnt working enough to stop the car . And no pics yet it happened last nite in the dark so didnt get a good look at the car. Im gonna organise a tilt tray this week. Not to keen on leaving it on the side of the road. And yea i was so suprised it had the balls to pull it. everything was going so smoothly till that happened. And for the force of the collision the kia wasnt actually to damaged. cos it hit down low. Because of the Soarer shape the front acted like a scoop and lifted his car up a bit. |
Damian Ware
Posts: 1299 Reg: 10-2005
| Rough figure without power assist most modern brake systems require 76kg to develop maximum braking force. Yes you can tow a car but there is a certain distance the cars must be apart. |
Michael Brown
Posts: 247 Reg: 07-2009
| ah fair enough. well i only weigh like 60 kgs haha. and im hoping I havent damaged the radiator or airbag compressor |
Tim Ross
Goo Roo Qld 1J + GT3582R (6+1>8)
Posts: 1553 Reg: 09-2007
| In QLD it is illegal. Add to that, towing a 1600kg plus vehicle with a hatchback that has a towing capacity of 1100kg is dumb at best, no matter how good his intentions were. Count yourselves lucky it wasnt any worse. |
Goo Roo QLD GT Starlet
Posts: 3377 Reg: 07-2005
| Handbrake |
Michael Brown
Posts: 248 Reg: 07-2009
| haha yea well i said to him before we started moving that if anything happens then its not my problem. I thought it would of blown his car up : / and i doubt the little kia has a towning capacity of 1100kgs lol probably less |
Tim Ross
Posts: 1554 Reg: 09-2007
| Hayman Reece towing systems to suit a Kia Rio are rated to 1100kg, which would be the vehicles maximum as legally they cannot rate a tow system high than what the vehicles capabilities are |
Aaron Casey
Posts: 1731 Reg: 08-2005
| id actually take your mates rear bar off id say its crumpled the reinforcement bar and then the rear bar has just popped back out. about a month ago i saw a kingswood towing a vb commodore and it was that close was like it was attached to the towbar. they were doing 100 down the highway.. never heard of them crashing but jesus that would have been dangerous if they had to stop quick |
Michael Brown
Posts: 249 Reg: 07-2009
| oh fair enough Tim haha thats pretty good for such a small car . And yea his crash bar is quite bent we had a look when we reattached his rear bar. but you can hardly tell its been hit by a car lol appart from my number plate indentation in the bak of his car haha |
Aiden Cheese
TryHard QLD Soarer jzz30
Posts: 303 Reg: 09-2009
James Harris wrote on Monday, January 18, 2010 - 11:48 am:Handbrake
Damian Ware wrote on Monday, January 18, 2010 - 10:27 am: And the brakes will still work without power assist it just requires a lot of effort to push the pedal.
QFT |
Posts: 11245 Reg: 11-2004
Michael Brown wrote on Monday, January 18, 2010 - 10:21 am:when i first took off they were working but after about 5 mins of towing i went to check them again and they didnt work at all !
That is normal, as the vacuum booster still worked for a few applications, then lost power as the vacuum wasn't being replenished. |
Michael Brown
Posts: 253 Reg: 07-2009
| ohh ok then. I get why now. |
Mark Tierney
TryHard NSW Soarer GTT, Celsior, Duc
Posts: 382 Reg: 09-2005
| In NSW it can only be done with a solid bar between the cars. Tow rope or chain is illegal. |
Aiden Cheese
Posts: 305 Reg: 09-2009
Peter Nitschke wrote on Monday, January 18, 2010 - 03:09 pm:That is normal, as the vacuum booster still worked for a few applications, then lost power as the vacuum wasn't being replenished.
Still should have been able to just pump his foot a couple of times and then held it down right? Much like you would if you were bleeding the brakes. |
Peter Burrett
DieHard ACT '97 2.5 VVTi ST, '04 IS200, '94 3 ltr Soarer
Posts: 660 Reg: 07-2005
| Pumping the pedal may work if there's a bit of air in the system, or if there's no power assist fitted, but as Pen says, if there is power assist and the servo has no vacuum, then you are down to leg power only; pumping won't help. Standing with all your might on the pedal may, and as was mentioned earlier, don't forget the handbrake.... but I think it takes about 500m to stop a Soarer from 60kmh with just the handbrake (why do the Americans call it an emergency brake?? By the time you stop, you are part of the emergency) |
Michael Brown
Posts: 256 Reg: 07-2009
| yea the handbrake is pretty much useless that was one of the things i tried but had very little response |
Miles Baker
Goo Roo Vic 66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 69 Nova SS Clone, 65 Mustang Fastback, 67 Mustang Convertible, 67 Camaro RS/SS
Posts: 2097 Reg: 08-2005
| You should probably look at fixing your handbrake then. It should give half decent response. |
Ben Lipman
Goo Roo NT Soarer TT manual, plus TT track car
Posts: 1892 Reg: 04-2006
| It is called an emergency brake because it will still work if your braking system has failed. My handbrake works very well. It will stop the car dead from lower speeds (20-30kph), but I have to admit I've never tried from 60kph. Biggest issue for me is not locking the rears up (obviously). And I hope this thread is not a revelation to too many members- slack towing a car is problematic with the rear car idling (so all assisted systems work), let alone with no power steer and minimal braking performance. In an emergency it can be done with longer ropes and very low speeds, but, well I guess you learnt a lesson you won't forget in a hurry. |
Posts: 11246 Reg: 11-2004
| Pumping shouldn't be necessary, just a lot of force. In the beginning, they used drum brakes, but they had limitations such as not cooling very quickly. Then disk brakes came along, cooled really well, but less braking force due to a lot less friction area being available. So power assist was added to aid the leg muscles. It's a bit like having a big buddy with his own pedal that presses when you do - power ASSIST. Without the power assist, eg engine not running on a vacuum assist system, your big buddy is no longer pressing. The brakes still work, but you have to push really hard and make all the pressure yourself. Similar with power steering, it is actually power assisted steering and works in the same way in that it helps you to turn the steering wheel, but the steering will still work without it, just not easily. |
Damian Ware
Posts: 1302 Reg: 10-2005
Peter Nitschke wrote on Monday, January 18, 2010 - 07:33 pm:Pumping shouldn't be necessary, just a lot of force. In the beginning, they used drum brakes, but they had limitations such as not cooling very quickly. Then disk brakes came along, cooled really well, but less braking force due to a lot less friction area being available. So power assist was added to aid the leg muscles.
Thats it exactly. Your legs should be able to push 76kg of force or at least enough to stop the car. Sit in a chair and use scales and push against the brick wall this will give you some idea of the force required. |
Goo Roo North Island JZZ31
Posts: 5103 Reg: 10-2005
| Of course, towing an automatic like that any distance at speed will root the transmission pretty quick. |
Michael Brown
Posts: 259 Reg: 07-2009
| even in N ? |
Dave Rose
Goo Roo wa uzz31 v8
Posts: 1123 Reg: 03-2007
| Yes, need to pick up rear wheels or remove prop |
Posts: 5109 Reg: 10-2005
| No fluid pressure and circulation means there is not enough lubrication or cooling going on. Usually only takes a few KM and the damage is done. |
Lew Radbourn
Goo Roo Queensland / Goodna jzs147 93 TT / uzz30 93'/
Posts: 3077 Reg: 07-2005
| Michael; Some one has to say it mate... You clown.hahahhahaha Never tow an automatic with out removing the drive shaft. Never expect a car to stop properly with out its brake assistance unless the car has none from the factory.which would make it a pretty old car well mate at least you learnt even be it the hard way and no one was injured |
Goo Roo WA Soarer TT & Corolla
Posts: 4633 Reg: 09-2005
| RAC memberships are pretty cheap >.> |
Posts: 3392 Reg: 07-2005
| more importantly --> WHERE ARE THE PICS ?? I wanna see the carnage ! |
Michael Brown
Posts: 263 Reg: 07-2009
| haha yeh i feel like a clown . Ah well i wont be doing it like that again. Id rather pay for a tilt tray haha. |
Goo Roo Victoria (The Nazi State) Active V8 and the Beast.
Posts: 2329 Reg: 07-2005
| Just to top it off, I know a few towies in qld who will do local tows for $50. Half the price of a used bonnet. |
