Marc Hoffmann
TryHard Vic Soarer TT
Posts: 177 Reg: 07-2009
| Just for fun I am due to send my car to cihan in 9 hours for a tune, thought we could have some fun and have a guessing game. 1. rwkw its at now (pretune) 2. rwkw after tune. a tip to help, mods are in my profile and build thread, and the "after" tune will be somewhat limited as i dont want exploding gearbox's. |
Ali Saeed
Goo Roo WA UZZ31
Posts: 1957 Reg: 09-2007
| 1. 2rwkw 2. 1.1rwgigawatts |
Warren Moore
TryHard Victoria JZZ31 2JZ-GE
Posts: 189 Reg: 01-2010
Ali Saeed wrote on Tuesday, March 16, 2010 - 11:32 pm:1rwgigawatts
hahahaha |
Nathan Hlad
DieHard NT JZZ30 TT
Posts: 601 Reg: 09-2008
lol you been smokin crack again ali ?? if so can you get me some too ? |
Matt Newman
TryHard QLD soarer tt
Posts: 197 Reg: 11-2007
| im going to have a stab in the dark and say before 220kw after 350 ish |
Mark Tierney
TryHard NSW Soarer GTT, Celsior, Duc
Posts: 443 Reg: 09-2005
| after 270rwkw |
Ben Lipman
Goo Roo NT Soarer TT manual, plus TT track car
Posts: 2026 Reg: 04-2006
| Before: 140 After: zip- it'll do a head gasket or burn a valve. What? Never heard of a long odds bet? |
Marc Hoffmann
Posts: 178 Reg: 07-2009
| Haha knew there would be some silly ones, hope it doesn't go bang haha. Ima guess: 217 before 267after with hopefully alot of midrange, I asked for a tune that won't kill the gearbox, give me much improved lean cruise Econ and the power would be suited to drag racing not dyno queen. |
James Cahir
TryHard ACT Soarer TT
Posts: 366 Reg: 04-2008
| before - 244kw after- 276kw |
Ali Saeed
Goo Roo WA UZZ31
Posts: 1958 Reg: 09-2007
| Nathan, no crack here mate, only natural stuff from the ground. |
Warren Moore
Posts: 191 Reg: 01-2010
| good 'ol botswanan 'omegrown |
Jesse Twartz
Tinkerer South Australia Soarer TT
Posts: 29 Reg: 02-2010
Ali Saeed wrote on Tuesday, March 16, 2010 - 11:32 pm:1. 2rwkw 2. 1.1rwgigawatts
That is by far the funniest thing I've heard all week |
Andrew Duaso
DieHard Victoria G6E turbo
Posts: 574 Reg: 02-2009
| 1.21 gigawats @ 88mph after cihan retunes the flux capacitator |
Sebastian Grant
DieHard nsw soarer TT
Posts: 944 Reg: 01-2008
| Is your profile up to date? If it is there's not much point getting it tuned with out getting injectors and a fuel pump. |
Nathan Hlad
DieHard NT JZZ30 TT
Posts: 606 Reg: 09-2008
| i recently got my flux capacitor and photon generator re-tuned and it chirps like a mutant man-eating parrot now lolol |
David Tra
Goo Roo qld AWD
Posts: 1416 Reg: 11-2007
| 9 hours to tune a piggy back???? abit excessive dont you think? |
Marc Hoffmann
Posts: 179 Reg: 07-2009
| everyones a comedian haha. have to wait till next week as there was a problem with my emanage unit, took most of the day to sort but its running a slightly tweeked base tune, feels a bit better.
Scott Wilkes
Goo Roo Tasmania 92 TT Factory Manual, 70 HG GTS Monaro
Posts: 1347 Reg: 10-2008
| in case your being serious david, he is getting the tune done in 9 hours, the tune its self isnt taking 9 hours |
Tony Nguyen
TryHard Victoria Soarer TT
Posts: 191 Reg: 09-2008
| I'm getting my tune next Monday as well! I wonder what figures i would get... |
Mark Tierney
Posts: 444 Reg: 09-2005
Mark Tierney wrote on Wednesday, March 17, 2010 - 08:37 am:
these upgrades with no injectors?? 240 if that's the case. |
Aaron Casey
Goo Roo nsw '94 jzz30 gttl, 2 mini's one supercharged
Posts: 2005 Reg: 08-2005
| 42 thats the answer isnt it? (from hitchikers guide to the galaxy) lol its after it should be done so what did you get? i think with cihan tuning around 270rwkw on 20psi with 98 octane |
Lew Radbourn
Goo Roo Queensland / Goodna jzs147 93 TT / uzz30 93'/
Posts: 3136 Reg: 07-2005
| Yer depends on the how much fuel is supplied to what cihan can do with it. stock injectors around 220 -240 MAX 440's safely around 250-270 Maxed out 290 (with a new pump) above that the T3G's will be maxing out so I recon around 280 -300 MAX if fuel and pump is done |
Sebastian Grant
Posts: 947 Reg: 01-2008
| I can't wait to see what you make, your mods basically mirror mine. |
Sebastian Grant
Posts: 949 Reg: 01-2008
| Aargh, when are you getting your tune Marc? |
Marc Hoffmann
Posts: 187 Reg: 07-2009
| thought i mentioned it above, its booked in on Wednesday. as there was a problem with my emanage that had to be fixed, thats why no results were put up last week. p.s. it has 440's in it for those wondering |
Sebastian Grant
Posts: 950 Reg: 01-2008
| Oh snap, I don't know how I missed that. I'm guessing 281rwkw |
Rob Rojo
Goo Roo NSW Soarer TT
Posts: 3725 Reg: 02-2010
| What boost are you running? Based on about 14psi untuned around 215rwkw tuned @ 20psi 265rwkw. |
Rob Rojo
Posts: 3726 Reg: 02-2010
| I also sent you the copy of the software but your email rejected it, you might have a 3mb limit and the file is a bit over 5mb. |
Posts: 11479 Reg: 11-2004
| Files grow by approx 50% when attached to emails due to the encoding used, so the 5Mb file would be more like a 7.5Mb email. |
Marc Hoffmann
Posts: 192 Reg: 07-2009
| Started off ok untill of blue smoke poured out the back.... 228rwkw at 17psi verdict engine seals are boned..... New motor time for me.... |
Gary Rollason
TryHard Qld TT 5 speed
Posts: 219 Reg: 05-2007
| So, looks like Bens' the winner! Shoulda put $50 on it! Bad luck though, Marc. :-( |
Sebastian Grant
Posts: 951 Reg: 01-2008
| Bad luck Marc. Time for a 2j. |
Bobby Green
TryHard QLD TT
Posts: 492 Reg: 09-2005
| 2J bottom end time, you won't regret it. |
Marc Hoffmann
Posts: 194 Reg: 07-2009
| yeah cihan has already talked me into a 1.5j going to take a while to save for it though, i hope this motor soldiers on for a while. its running at 9 psi so like 170rwkw atm... oh turns out my boost controller is dead too, as cihan ripped it out for a boost T and boost went straight up... very bumbed about what happened, but thanks go to cihan as hes a top bloke and very willing to help. |
Sebastian Grant
Posts: 952 Reg: 01-2008
| It sucks but the 2j bottom end will help with lag, what rpm did you start to make positive boost at? I'm finding that the t3gs are a lot laggier than people have reported but that may be due to my tune or lack ther of. |
Andrew Duaso
Posts: 579 Reg: 02-2009
| nahhh stop smoke and she'll be right ;) you'd be supprised how long a engine can last.... i had a supercharged 3.5L 6g74 (mitsubishi) and the crown of a piston cracked so i was down to 5 cyl, that didnt stop me chopping a mildly modded 5L commo a few times then much more thrashing and she was down to pretty much 3 cyls and the idle quality was pretty bad, yet still chopped some V6's sure i had a s/c but there was bits of piston in the cat and bent valves on them cyls.... long story the sh!tbox just kept going and going, $700 wrecker motor and it was good as new note to all magna motors suck at boost, power can be made, lots can be made actually but you need to put on the work there is a 3L getting around NSW with 507hp atw! LOL |
Moderator etuner.com.au JZZ30
Posts: 3209 Reg: 07-2005
| Sometimes pushing up the boost causes tired engines (this one has 270,000kms) to burn oil for several reasons. The oil is forced through if the worn rings cause enough blow by to pressurise the sump (if the standard breather can't cope, for example). Oil is forced into the combustion chambers which causes detonation / preignition and limits performance. It also doesn't allow the oil return to function properly. Over a long period of time, especially if neglected and abused, the engine will simply get worse and start chewing oil. It can also damage turbochargers. As mentioned by others, i agree it'll be fine for many thousands of kms if left at 9psi and driven with 'incidental' sprints. Mate, 1.5JZ's are easy. I'm building one for the track car, it'll be high comp and have a HX40 strapped to the side of it ;) Cheap as chips. |
Marc Hoffmann
Posts: 195 Reg: 07-2009
| i was getting 10 psi by 3000rpm with the t3g's after some tune tweeking, cihan was confident on improving that though. biggest effect on the t3gs i found was cam gears, i had min set at ex 3 notches retaded (6' at crank) and intake at +1. now the saving begins, im gutted by the last week, but at least theres some light at the end of the tunnel i spose... |
Ben Lipman
Posts: 2035 Reg: 04-2006
| I win! you do realise I was joking, right? Sounds like the start of an epic build outta street machine or HPI. "So I pulled it off the road and went all out. I only wanted a bit more power in a daily driver but it all got out of hand..." |
Sebastian Grant
Posts: 954 Reg: 01-2008
| Cihan, after driving mine around a few times I've changed my mind on what I want. I wanted get 300rwkw but now I'm more concerned with achieving a nice power curve. Would you suggest ditching the plan to get cams and instead get some cam gears? |
Aaron Casey
Posts: 2023 Reg: 08-2005
| sebastian cams should make more power than cam gears. but if you are going to rip everything apart id recommend doing both at same time. i noticed a big difference in my 1j with 256/264 cams over adjusting the cam gear. so much im not even sure i want to put my adjustable cam gears on my 2j as they are heavier. |
Aaron Casey
Posts: 2024 Reg: 08-2005
| oh yeah sorry to hear mark im halfway doing the same. motor is my weak link lol but im going 2j conversion. if that starts to blow blue ill be very unhappy |
Posts: 3211 Reg: 07-2005
| Sebastian, cams are a good idea but do keep in mind that there's a bottom end penalty. Cam gears don't really make a big difference with standard cams, especially where you want to retain lowend and strong idle. Retarding the ex camgear works against that. 215/215 @ 0.50 lift cams with 9.3mm lift, or 9.5mm lift with springs, would be my pick. Let me run some numbers.. |
Sebastian Grant
Posts: 958 Reg: 01-2008
| I think I'll wait to see how Mark goes with his 2j conversion before I spend anymore money on my 1j. Depending on how his goes I'll either do the same or put a v8 with one of your turbo kits Cihan which I think is the ultimate setup. The low down torque of a v8 coupled with the high end power of a turbo, perfect for the street. |
