  Soarer Central * General Soarer Chat * Exhaust question Previous Previous    Next Next
Kevin Fang
Nsw
SC400 v8
Reg: 05-2007
Thursday, July 29, 2010 - 02:53 pm, by:  Kevin Fang  (Kevin_f) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Just wondering what are some ways to make my v8 sound better, i really dont wanna fork out 2000$ for extractors. Ive watched some vids on youtube about people removing the mufflers which really made it sound good, What are your suggestions?
Kevin
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 02:59 pm, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can do it cheaply if you remove the stock mufflers, resonators, and remove the middle cat. Put some straight pipes in there place with aftermarket mufflers on the end.
Kevin Fang
Nsw
SC400 v8
Reg: 05-2007
Thursday, July 29, 2010 - 03:15 pm, by:  Kevin Fang  (Kevin_f) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
would removing the cats make my car defective? Also what about cabin temperature?
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 04:00 pm, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It will be illegal if you remove all the cats, but since you have 3 (or 4) what you can do is keep the cats right behind the headers, and remove all the remainders, what you should be left with is two cats which you can replace with high flows if money permits. Most people will replace them as the cats you have on the car now will most likely be old and clogged.
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 04:02 pm, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the sound is what your after, then this will give you that growl, but wont be as raspy and deep as a full system.
Kevin Fang
Nsw
SC400 v8
Reg: 05-2007
Thursday, July 29, 2010 - 04:17 pm, by:  Kevin Fang  (Kevin_f) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.youtube.com/watch?v=SGRV_T_-v-c&feature=related
This one sounds alright, what is a resonator?
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 04:32 pm, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Resonators are used in car exhausts as a form of silencer, same as a muffler. It uses the sound waves reflecting off the side wall of the special piping to cancel the other sound waves, as in creating resonance to cancel frequencies.
(I think its behind the second cat).
Daniel Blackham
31V8
Reg: 10-2009
Thursday, July 29, 2010 - 04:34 pm, by:  Daniel Blackham (Daniel24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone know what the two different stock pipe diameters are? So Kevin knows what to buy I guess.
Ben Lipman
Thursday, July 29, 2010 - 09:20 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Open bonnet, remove that thing in front of the gearbox, insert 1/1.5/2JZGTE and enjoy. Won't matter what it sounds like- the noise will be waaay behind you.
Kevin Fang
Nsw
SC400 v8
Reg: 05-2007
Friday, July 30, 2010 - 05:04 pm, by:  Kevin Fang  (Kevin_f) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sigh, why not just supercharge the v8? anyways thanks for your help Daniel ill pop into castle hill exhausts and see what they think. Looking to spend less than 500$
Ali Saeed
Friday, July 30, 2010 - 05:54 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
much easier to just buy one with a 1jz in it :p
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Friday, July 30, 2010 - 06:45 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
typical comment.
Stick with the V8 it's reliable/sounds good and you can always supercharge that.
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Saturday, July 31, 2010 - 03:11 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kevin Fang wrote on Friday, July 30, 2010 - 05:04 pm:
Fora bit over $500 you should be able to get a cat back. I got extractors back from CHE and if you take out the cost of cats its about $700 or so.
http://www.youtube.com/watch?v=8hjAwCSJjPs
