Thursday, August 12, 2010 - 09:51 pm, by: Daniel Clarke(Dieseltrain)
You will need a 10mm hex socket and a 12mm hex socket . Preferrably in 1/2 inch drive as the driveshaft bolts can be tight .
10mm for driveshafts , 12mm for diff mount bolts .
Also undo the FILL plug on the new diff before fitting . Alot of people have undone the DRAIN plug to find the FILL plug was stripped and couldnt fill em up ;)
