Warren Moore
DieHard Victoria JZZ31 N/A
Posts: 583 Reg: 01-2010
| which will fit the soarer? H1, H3, H7, H9, H11, 9005(HB3) or 9006(HB4)? and should i get 35w or 55w and why? |
Matt Newman
TryHard QLD soarer tt
Posts: 289 Reg: 11-2007
| the 9005/hb3 is the bulb you want as for the wattage its up to you i have 35w in mine and they are great but i have not had any experience with the 55w |
Damian Ware
Goo Roo Victoria UZZ32
Posts: 1739 Reg: 10-2005
| A top quality kit with correct globe design is more important than power output. That being said everything being equal a set of 55w HIDs are certainly better than 35w. |
Aaron Casey
Goo Roo nsw '94 jzz30 gttl, 2 mini's one supercharged
Posts: 2332 Reg: 08-2005
| says on the lights they should be hb4 but with new bulbs only hb3 fit. i dont know how many mates have got hb4 for their supra/soarer and they are too thick and wont go into the socket. 35 watt gives a little better light than normal 60w lights but try not to go over 6000k as will get really hard to see in the wet. the 55w hids are very very bright and will almost definitely get pulled up for them unless they are angled spot on but give a lot better light at expense to oncoming traffic |
Allan Langford
TryHard Vic UZZ31
Posts: 103 Reg: 05-2010
| you might find you need to swap the "o" ring from the original bulb to the HID bulb for them to fit... I just got the $60 something kit from some guy on ebay with soarer in his username! been working fine for months now! |
Warren Moore
Posts: 584 Reg: 01-2010
| yeah i just bought the 55w hb3 8000k kit off a guy called 95soarer from ebay for $120 something posted |
Joshua Rao
Goo Roo WA JZZ30 vvti auto GT-L, JZZ30 vvti turbo BLK on BLK manual, V8 UZZ31 (being wrecked), Legnum VR4
Posts: 1974 Reg: 09-2006
| there good man, i got them |
TryHard Auckland UZZ31 Soarer
Posts: 387 Reg: 03-2009
| I have the 9005 HID's in my soarer and from memory they are 35w, they all fit 9005 or 9006. Good bright light as mine are 4300k they take about 5-10 seconds to warm up but are so much better than the factory globes and you almost don't need high beam as you don't notice that much of a difference when you use high beam. |
Warren Moore
Posts: 585 Reg: 01-2010
| 8000k josh? got any pics? |
Aaron Casey
Posts: 2337 Reg: 08-2005
| i can guarantee that most of the hb4's out there wont fit. its not the o ring its the base is actually bigger by about 2mm. so when you buy them you will realise and will have to buy the hb3 bulbs and send the others back. also with the hb4's one of the tangs is bigger so you would have to cut part of the tang off at the side. |
Joshua Rao
Posts: 1977 Reg: 09-2006
| hey warren I got the 6000k and they were perfect. Sorry no pics |
Evan Kaio
DieHard Beautiful sunny good @ rugby 'Canes' country '91 UZZ31. 92 TT
Posts: 713 Reg: 01-2007
Aaron Casey wrote on Saturday, September 11, 2010 - 08:53 pm:i can guarantee that most of the hb4's out there wont fit. its not the o ring its the base is actually bigger by about 2mm. so when you buy them you will realise and will have to buy the hb3 bulbs and send the others back. also with the hb4's one of the tangs is bigger so you would have to cut part of the tang off at the side.
Yeah it's about 1-2mm too big. Aaron, any idea's as to what would the HB4 lamp fit? |
Warren Moore
Posts: 590 Reg: 01-2010
| ok so i fitted the 8k kit and they dont look 8k to me.. http://i.imgur.com/v4LJG.jpg http://i.imgur.com/I6eKN.jpg http://i.imgur.com/rJE89.jpg |
Aaron Casey
Posts: 2343 Reg: 08-2005
| they look like 6k did you get 55w or 35w? if you got the 55w will be brighter and usually less blue than the 35w 8k ones. |
Warren Moore
Posts: 591 Reg: 01-2010
| they are 8k 55w.. |
