Ali Saeed
Goo Roo WA UZZ31
Posts: 3130 Reg: 09-2007
| anyone know if this is a good kit? http://www.suprastore.com/tosuwifrkit1.html |
Rowan McMahon
TryHard WA GTT-L
Posts: 395 Reg: 07-2010
| ali theres a group buy on skylines australia - maybe try jump on with them see if they can offer a discount... ...in short a lot of the USA guys use them on supras.. and they seem to go apeshit for them. |
Aaron Mead
Posts: 2991 Reg: 03-2006
| Bottom of the barrel kit. The calipers themselves are only $~176 each. The rotors are crap, the pads are crap and the lines arent ADR. (throw em in the bin and use your Maltech ones, will fit). They are lug mount too, not such an issue for a rear kit, but on the front you'll only have one plane of adjustment with that type. Otherwise Just get the OEM 4 pot Jza80 kit. Looks good, and they only have to slow down a V8' . |
Ali Saeed
Goo Roo WA UZZ31
Posts: 3131 Reg: 09-2007
| yeh but how does it compare to supra 4pots? |
Aaron Mead
Posts: 2992 Reg: 03-2006
| Cant say, I've only used Wilwood SL6 radials on 330mm rotors. While they are advertised as a 13" kit, they are actually JZA 80 OEM size rotors. (324mm) So best guess is ......... much the same, only you dont have dust seals in the wilwoods. |
Aaron Mead
Posts: 2993 Reg: 03-2006
| You better re read that ad, its for a rear kit. It also starts off the spiel with "Wilwood has supplied brake packages to race teams for almost 50 years." But that isnt a Wilwood kit. |
Ali Saeed
Goo Roo WA UZZ31
Posts: 3132 Reg: 09-2007
| yeh i know im not buying from them but just using their link. where did you buy your sl6? they are around 380 a caliper, might have to go with taht route. |
Ali Saeed
Goo Roo WA UZZ31
Posts: 3133 Reg: 09-2007
| correction, sl6 lug mounts are 380. |
Aaron Mead
Posts: 2994 Reg: 03-2006
| I got my fronts second hand (rebuilt em ~$120), new dogbones from engineering technology. Bought new rear Wilwoods from Arizona Performance. Useless f*cking alumimium handbrake hat. Glad it used 324 mm rotors, replaced em with DBA 4000's. ( which are overkill, plain DBA would be more than enough...) |
Aaron Mead
Posts: 2995 Reg: 03-2006
| I reckon eBay would have a few dealers that can supply calipers only, calipers and dogbones, then you can get racebrakessydney or your local engineer to make the dogbones. |
Ali Saeed
Goo Roo WA UZZ31
Posts: 3134 Reg: 09-2007
| i see. whats the difference between lug and radial though? does it make a difference in braking? |
Aaron Mead
Posts: 2996 Reg: 03-2006
| Weight, adjustment, ridgidity and price. Get radials. |
Ali Saeed
Goo Roo WA UZZ31
Posts: 3135 Reg: 09-2007
| lastly Aaron what is the radial mount hole width for your calipers? 5.98 inch? |
Aaron Mead
Posts: 2997 Reg: 03-2006
| I think so, having looked at wilwood website. My engineer guy was given the old bones and a pdf from wilwood. |
